[postgis-users] problems restoring a dump : CREATE CAST?
Pedro Salazar pedro-b-salazar at ptinovacao.pt
Thu Apr 10 05:04:51 PDT 2003
I forgot to mention that I'm using Postgresql 7.3.2 and Postgis 0.7.4.
regards,
Pedro Salazar.
On Thu, 2003-04-10 at 12:57, Pedro Salazar wrote:
> Greetings,
> I'm using postgis functions in my database, and I'm getting errors
> restoring the database. I already identified the line problems, and it
> can reproduced just creating a database and running the postgis.sql
> procedures.
> The following statements are taken from the postgis.sql file, and they
> work just fine when running it:
> The following lines are the errors I'm getting when restoring the dump
> file:
> The lines below are the statements in the dump file that I think are
> throwing that errors:
> Please, anyone had reproduced these errors? What it means? Is there a
> workaround? Can I dump just schema tables and data from a specified
> schema that could avoids me restore the public postgis functions/tables,
> doing it manually before? (could be a possible workaround... no?).
> thanks,
> Pedro Salazar.
PS
PGP:0E129E31D803BC61
