[postgis-users] About $libdir
strk strk at freek.keybit.net
Fri Apr 11 07:00:49 PDT 2003
benjamin.thelen wrote:
> Hi, thanks again!
> Ok, I moved /usr/local/pgsql/lib/libpostgis.* (incl. the symlink) to
> /usr/local/lib/postgresql and used postgis.sql with $libdir and it worked in
> the same way like with absolute path. So, we were successful. But that too
> means that this is a bug in the installation of postgis?
Might be.. a "conceptual" but. I don't know what version of postgis
you are installing, if it is the latest version we should involve
Paul Ramsey in this discussion. Paul ?
> With which command would I use this -L switch, you recommended to use below?
> The linker, who is it? But I don't need to do that anymore?
No. you don't need it. The linker is needed when making an executable
from a set of objects that contain calls to function libraries, see ld(1).
> According to the statement, that postgis is an extension AND is compiled
> against postgresql, I can't decide on my own where to install postgis. Is
> pkglibdir then just an official recommendation then, as you write "should"
> be installed in --pkglibdir? But, as postgis.sql didn't work, it is more
> then a recommendation.
pkglibdir is just an official recommendation. If postgis.sql did not
work is probably because postgis has been packaged with a bit
of confusion about whether or not to follow the raccomendation and
how.
> How can I find out, where I installed postgis? You wrote "I thought your
> postgis got installed in `pg_config --libdir` but I understand now it's
> not." I don't. :-). I now suppose, that postgis was correctly installed
> into --pkglibdir (where can I configure that?), but did copy libpostgis.so*
> into the wrong directory.
Installing postgis "means" copying libpostgis.so* somewhere.
I don't know how to tell postgis where to be installed, it seems
to me that the installation path is taken from the postgres Makefile
which is included on top of the postgis Makefile. The way it is taken
though, might not be the right one (to follow recommendations).
I suggest (to the packager) to avoid using postgres source tree at all
if possible (not always the source tree reflects the installation layout)
and use pg_config instead.
Any comments about this Paul ?
> Thanks very much,
> Benjamin
> PS: I still get this output below using postgis.sql. I just ask in case
> there is any relation. Otherwise I think it will be a new posting as soon as
> I see something what I need is not working in postgis.
Let it be a new posting :)
--strk;
