[postgis-users] Call for Debuggers
Daniel Morissette
morissette at dmsolutions.ca
Tue Apr 15 09:33:51 PDT 2003
Paul,
Have you tried running the thing under Valgrind on Linux? It usually
does an amazing job, if there are memory management issues, then they
would quite likely be detected by Valgrind.
Daniel
Paul Ramsey wrote:
> If there's anyone who
> (a) has access to a Solaris box with a relatively recent build
> environment (autoconf >= 2.53, automake >= 1.6, recent libtool)
> (b) has an understanding of C++, gdb and memory management and
> (c) has a little time to walk through some code.
> We could use someone on geos-devel to take the current codebase under
> solaris and track down whatever it is that is causing instant segfaults.
> We suspect bad memory management, given Solaris's relative strictness in
> that area.
> Thanks,
> Paul
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> postgis-users mailing list
