[postgis-users] java.lang.OutOfMemoryError
Anthony Agoro (C)
Anthony.Agoro at ordnancesurvey.co.uk
Thu Dec 4 04:52:48 PST 2003
Hi Darren,
Nice to hear from you. I have a small challenge I hope you might help me see through.
When I try Getfeature to a table in my database, I get the following:
<ServiceException>UNCAUGHT EXCEPTION: java.lang.OutOfMemoryError</ServiceException>
1) Are there missing jars files required in the geoserver/lib directory that I may not have in place.
Then I thought this is for in the case of non open source backend like oracle, which requires
classes12.jar, which contains the jdbc classes, and sdoapi.jar, which contains the spatial api jars.
2) is there an issue with resin 2.1.11 when uploading large files via http
3) is there a memory utilization issue with PostgreSQL/PostGIS in that could it be that database calls are not getting a close() call and remains open with chunks of memory.
Darren I know you are familier with my environment, the following are for the benefit of others.
I am running on linux 7.3 with resin2.1.11 (i386) with PostGIS 0.7.4 on top of Postgresql 7.2.3
Many thanks,
Anthony
How've you been. What's GeoServer 1.0.1 like and are the reported minor fixes really minor?
Is it worth upgrading to GeoServer 1.0.1 straight away.
I have been away and just returned to work, thus slow response.
I still need to send you detail of the conversion process from Oracle spatial to shapefile. I am currently loading the shapefile of osmastermap (area, point,boundary,line, sym, Anno) into their individual tables.
Have you tried the GeoTools2 GIS toolkit that comes with it, is the limited feature really limited?
If you have received this email in error, please delete it immediately and notify the sender.
This email may contain confidential information and if you are not the intended recipient, you must not copy, distribute or rely on it.
As email is not a 100% secure communications medium, you accept that there are risks in communicating by email by doing so. We advise you to check that emails and attachments are virus-free before opening them. No contracts can be entered into on our behalf by email. Opinions expressed in this email are not necessarily endorsed by us unless otherwise specifically stated. We reserve the right to read and monitor any email or attachment entering or leaving our systems without prior notice.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 023 8079 2000
http://www.ordnancesurvey.co.uk
