[postgis-users] Performance and memory problems
Andrea Aime
andrea.aime at aliceposta.it
Thu Dec 4 07:32:47 PST 2003
strk wrote:
> andrea.aime wrote:
>>strk wrote:
>>>What C++ compiler do you have (name/version) ?
>>Libraries are:
>>gcc 3.2.2 (Mandrake Linux 9.1 3.2.2-3mdk)
>>glibc version 2.3.1
>>libstc++5-3.2.2
> You can try disabling the memory cache feature of libstdc++ by
> exporting GLIBCPP_FORCE_NEW=1 before starting the postgresql
> postmaster. This might save some memory.
Does not work :-(
> I've had problems with 3.2.2 also try to upgrading to 3.3.2.
Updating the compiler is a bit out of my reach, I don't have enough
time to fiddle with gcc removal and installation from sources.
I will try at home where I have a mdk 9.2 which uses 3.3.1.
> Ask on the pgsql-hackers mailing list about postmaster
> stack trace (and please let me know).
Will do. I've also noted something strange: before maxing out memory
vmstat reports that the cpu is used almost 100% by system tasks, not
user ones... look at this "vmstat 1" output:
(A): here I started the query
(B): here it starts spinning like mad in the system area
(C): boom
0 0 0 69464 35592 117008 0 0 0 120 117 101 0 2 98 0
3 0 0 65148 35592 117700 0 0 0 0 103 90 58 8 34 0 (A)
procs -----------memory---------- ---swap-- -----io---- --system-- ----cpu----
r b swpd free buff cache si so bi bo in cs us sy id wa
1 0 0 64672 35592 117836 0 0 0 0 101 61 69 31 0 0
2 0 0 66832 35592 117972 0 0 0 0 101 59 50 50 0 0
1 0 0 66960 35592 118092 0 0 0 0 101 62 63 37 0 0
2 0 0 66020 35592 118228 0 0 0 200 128 75 61 39 0 0
1 0 0 65032 35592 118308 0 0 0 0 102 63 55 45 0 0
1 0 0 66292 35592 118444 0 0 0 0 101 68 54 46 0 0
1 0 0 65444 35592 118564 0 0 0 0 101 72 72 28 0 0
1 0 0 66444 35596 118672 0 0 4 0 102 73 46 52 2 0
1 0 0 65144 35596 118880 0 0 0 180 127 88 54 46 0 0
1 0 0 66176 35596 119048 0 0 0 0 102 68 59 41 0 0
1 0 0 64264 35596 119320 0 0 0 0 102 74 77 23 0 0
1 0 0 64076 35596 119432 0 0 0 0 102 74 50 50 0 0
1 0 0 62732 35596 119536 0 0 0 0 101 79 84 16 0 0
2 0 0 62596 35596 119536 0 0 0 228 119 83 89 11 0 0
1 0 0 62532 35596 119536 0 0 0 0 101 75 10 90 0 0
1 0 0 62520 35596 119536 0 0 0 0 101 77 5 95 0 0 (B)
1 0 0 61328 35596 119536 0 0 0 0 101 80 5 95 0 0
1 0 0 61496 35596 119536 0 0 0 0 101 76 4 96 0 0
1 0 0 62508 35596 119536 0 0 0 24 105 82 10 90 0 0
1 0 0 60296 35596 119536 0 0 0 0 101 71 5 95 0 0
1 0 0 60772 35596 119536 0 0 0 0 101 66 3 97 0 0
1 0 0 60812 35596 119536 0 0 0 0 101 70 6 94 0 0
1 0 0 61604 35596 119536 0 0 0 0 101 70 2 98 0 0
2 0 0 65208 35596 119744 0 0 0 28 106 79 21 79 0 0
1 0 0 64224 35596 119864 0 0 0 0 101 68 91 9 0 0
1 0 0 64548 35596 120012 0 0 0 0 101 66 71 29 0 0
0 0 0 69716 35596 117268 0 0 16 1548 172 123 15 27 58 0 (C)
0 0 0 69716 35596 117268 0 0 0 0 101 64 0 0 100 0
0 0 0 70140 35596 117268 0 0 0 136 123 116 0 1 99 0
I wonder why it is starting to behave like this at B since the postmaster process
never uses more than 20 MB on the RSS column of the "top" output...
Andrea
