[postgis-users] make on Mac OS 10.2.8
Sean Gillies
sgillies at frii.com
Fri Dec 5 08:16:31 PST 2003
On Friday, December 5, 2003, at 06:08 AM, David Orme wrote:
> Hi,
> Can someone tell me where I'm going wrong? I've installed PostgreSQL
> 7.3.3...
>> [doibook:local/src/postgresql-7.3.3] dorme% /usr/local/pgsql/bin/psql
>> --version
>> psql (PostgreSQL) 7.3.3
>> contains support for command-line editing
> and also installed GEOS...
>> [doibook:local/src/postgresql-7.3.3] dorme% ls /usr/local/lib/libgeos*
>> /usr/local/lib/libgeos.1.0.0.dylib /usr/local/lib/libgeos.a
>> /usr/local/lib/libgeos.la
>> /usr/local/lib/libgeos.1.dylib /usr/local/lib/libgeos.dylib
> and PROJ...
>> [doibook:postgresql-7.3.3/contrib/postgis] dorme% proj
>> Rel. 4.4.7, 31 March 2003
>> usage: proj [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
>> [doibook:postgresql-7.3.3/contrib/postgis] dorme% ls
>> /usr/local/include/proj*
>> /usr/local/include/proj_api.h /usr/local/include/projects.h
>> /usr/local/lib/libproj*
>> /usr/local/lib/libproj.0.4.1.dylib /usr/local/lib/libproj.a
>> /usr/local/lib/libproj.la
>> /usr/local/lib/libproj.0.dylib /usr/local/lib/libproj.dylib
> on my Mac OS X (10.2.8) machine but when I try and make postgis, make
> reports syntax errors all over the place. I've appended the make
> output - what I do that leads up to it is:
>> [doibook:src/postgresql-7.3.3/contrib] dorme% cd
>> /usr/local/src/postgresql-7.3.3/contrib
>> [doibook:src/postgresql-7.3.3/contrib] dorme% sudo curl -O
>> http://postgis.refractions.net/postgis-0.8.0.tar.gz
>> [doibook:src/postgresql-7.3.3/contrib] dorme% sudo tar -zxvf
>> [doibook:src/postgresql-7.3.3/contrib] dorme% cd postgis-0.8.0
>> [doibook:postgresql-7.3.3/contrib/postgis-0.8.0] dorme% vi Makefile
>> [doibook:postgresql-7.3.3/contrib/postgis-0.8.0] dorme% make
> I've checked the makefile parameters and everything looks correct -
> any suggestions?
> Thanks,
> David
David,
I've been able to build it on 10.2.8. I'm using postgresql-7.3.4 and a
CVS
snapshot of postgis from ~ 2 September. I'll download the 0.8 release
and
see what happens with that.
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
