[postgis-users] make on Mac OS 10.2.8
David Orme
d.orme at imperial.ac.uk
Fri Dec 5 08:50:30 PST 2003
I've just tried installing the CVS snapshot:
sudo curl -O http://postgis.refractions.net/postgis-cvs.tar.gz
sudo tar -zxvf postgis-cvs.tar.gz
make
and I get the same output from make as before. I wondered briefly it it
is a permissions problem but 'sudo make' is no better.
David
On Friday, December 5, 2003, at 04:16 pm, Sean Gillies wrote:
> On Friday, December 5, 2003, at 06:08 AM, David Orme wrote:
>> Hi,
>> Can someone tell me where I'm going wrong? I've installed PostgreSQL
>> 7.3.3...
>>> [doibook:local/src/postgresql-7.3.3] dorme%
>>> /usr/local/pgsql/bin/psql --version
>>> psql (PostgreSQL) 7.3.3
>>> contains support for command-line editing
>> and also installed GEOS...
>>> [doibook:local/src/postgresql-7.3.3] dorme% ls
>>> /usr/local/lib/libgeos*
>>> /usr/local/lib/libgeos.1.0.0.dylib /usr/local/lib/libgeos.a
>>> /usr/local/lib/libgeos.la
>>> /usr/local/lib/libgeos.1.dylib /usr/local/lib/libgeos.dylib
>> and PROJ...
>>> [doibook:postgresql-7.3.3/contrib/postgis] dorme% proj
>>> Rel. 4.4.7, 31 March 2003
>>> usage: proj [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
>>> [doibook:postgresql-7.3.3/contrib/postgis] dorme% ls
>>> /usr/local/include/proj*
>>> /usr/local/include/proj_api.h /usr/local/include/projects.h
>>> /usr/local/lib/libproj*
>>> /usr/local/lib/libproj.0.4.1.dylib /usr/local/lib/libproj.a
>>> /usr/local/lib/libproj.la
>>> /usr/local/lib/libproj.0.dylib /usr/local/lib/libproj.dylib
>> on my Mac OS X (10.2.8) machine but when I try and make postgis, make
>> reports syntax errors all over the place. I've appended the make
>> output - what I do that leads up to it is:
>>> [doibook:src/postgresql-7.3.3/contrib] dorme% cd
>>> /usr/local/src/postgresql-7.3.3/contrib
>>> [doibook:src/postgresql-7.3.3/contrib] dorme% sudo curl -O
>>> http://postgis.refractions.net/postgis-0.8.0.tar.gz
>>> [doibook:src/postgresql-7.3.3/contrib] dorme% sudo tar -zxvf
>>> [doibook:src/postgresql-7.3.3/contrib] dorme% cd postgis-0.8.0
>>> [doibook:postgresql-7.3.3/contrib/postgis-0.8.0] dorme% vi Makefile
>>> [doibook:postgresql-7.3.3/contrib/postgis-0.8.0] dorme% make
>> I've checked the makefile parameters and everything looks correct -
>> any suggestions?
>> Thanks,
>> David
> David,
> I've been able to build it on 10.2.8. I'm using postgresql-7.3.4 and
> a CVS
> snapshot of postgis from ~ 2 September. I'll download the 0.8
> release and
> see what happens with that.
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://www.frii.com/~sgillies
> postgis-users mailing list
