[postgis-users] make on Mac OS 10.2.8
David Orme d.orme at imperial.ac.uk
Mon Dec 8 01:34:13 PST 2003
Aha.
I'm using the most recent apple gcc release 3.3
> [doibook:~] dorme% gcc -v
> Reading specs from /usr/libexec/gcc/darwin/ppc/3.3/specs
> Thread model: posix
> gcc version 3.3 20030304 (Apple Computer, Inc. build 1493)
If I switch back to 3.1 (sudo /usr/sbin/gcc_select 3.1) and use the
same compiler as Sean (Apple Computer, Inc. GCC version 1175, based on
gcc version 3.1 20020420 (prerelease)) then make runs, although I do
get the same error messages Sean reported. I can't remember which
version I used to compile postgresql so it might be a mismatch between
compiler versions but the syntax errors look like they crop up early in
the math.h includes provided by apple. I haven't tested whether the
installed code works yet but hopefully the gcc version switch is all I
needed - thanks for your help, Sean.
Cheers,
David
On Friday, December 5, 2003, at 05:43  pm, Sean Gillies wrote:
> On Friday, December 5, 2003, at 09:50  AM, David Orme wrote:
>> Hi,
>> I've just tried installing the CVS snapshot:
>> sudo curl -O http://postgis.refractions.net/postgis-cvs.tar.gz
>> sudo tar -zxvf postgis-cvs.tar.gz
>> make
>> and I get the same output from make as before. I wondered briefly it
>> it is a permissions problem but 'sudo make' is no better.
>> David
> David,
> I downloaded postgis-0.8.0 and it made with only two warnings:
> bash-2.05a$ make
> gcc -traditional-cpp -g -O2 -Wall -Wmissing-prototypes
> -Wmissing-declarations -g -fexceptions   -I. -DFRONTEND
> -DSYSCONFDIR='"/usr/local/pgsql/etc"'  -DUSE_VERSION=73
> -I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include -DUSE_PROJ
> -DUSE_STATS  -I../../src/include   -c -o postgis_debug.o
> postgis_debug.c
> cc1: warning: changing search order for system directory
> "/usr/local/include"
> cc1: warning:   as it has already been specified as a non-system
> directory
> postgis_debug.c: In function `lockcheck':
> postgis_debug.c:310: warning: control reaches end of non-void function
> I don't know what is causing your error and I cannot reproduce the
> error.
> FWIW here's the version of my gcc:
> bash-2.05a$ gcc -v
> Reading specs from /usr/libexec/gcc/darwin/ppc/3.1/specs
> Thread model: posix
> Apple Computer, Inc. GCC version 1161, based on gcc version 3.1
> You have the latest Apple Developer stuff?
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://www.frii.com/~sgillies
> postgis-users mailing list
