[postgis-users] Query result correct ?
Alexander Pucher
pucher at atlas.gis.univie.ac.at
Tue Dec 9 12:38:28 PST 2003
I'm doing an sql query on my DB that looks like this:
select aut_bez_w.the_geom,aut_bez_w.oid,temp_2.value,case
when temp_2.value > 0.507 then 1
when temp_2.value > 0.4674 then 2
when temp_2.value > 0.4476 then 3
when temp_2.value > 0.4278 then 4
else 5
end as myclass
from aut_bez_w,temp_2
where aut_bez_w.bezirk_id = temp_2.id
the maximum value of 'temp_2.value' is 0.507, so I would assume that
this this entry will end up in 'case 2', but it does not. The case for
0.507 is 1!!
I don't really understand why the this happens? The query seems clear to
me: All numbers greater (not greater equal !!) 0.507 --> case 1, all
greater 0.4674 --> case 2 etc.
BTW, the same happens if I do this:
else 5
end as myclass
Any hints?
Regards,
alex.
