[postgis-users] function definitions fail to load.
David Orme
d.orme at ic.ac.uk
Tue Dec 9 08:43:51 PST 2003
I've tried loading the function and object definitions after compiling
and installing the postgis code and something is going wrong. It looks
like it fails to load libpostgis, which aborts the whole of the rest of
the load. The library is there:
> [doibook:/usr/local/pgsql] dorme% file lib/libpostgis.so.0.8
> lib/libpostgis.so.0.8: Mach-O bundle ppc
Any suggestions?
Thanks,
David
The process is:
553 16:31 sudo curl -O
http://postgis.refractions.net/postgis-0.8.0.tar.gz
554 16:32 sudo tar -zxvf postgis-0.8.0.tar.gz
554 16:32 cd postgis-0.8.0
555 16:33 vi Makefile
556 16:33 sudo make
557 16:34 sudo make install
558 16:35 cd /usr/local/pgsql/
559 16:35 bin/createlang plpgsql ebcc
560 16:36 bin/psql -d ebcc -f share/contrib/postgis.sql
But then the function loading does this:
[doibook:postgresql-7.3.3/contrib/postgis-cvs] dorme%
/usr/local/pgsql/bin/psql -d ebcc -f postgis.sql
BEGIN
message
PL/PgSQL is installed.
(1 row)
psql:postgis.sql:38: NOTICE: ProcedureCreate: type histogram2d is not
yet defined
psql:postgis.sql:38: ERROR: Load of file
/usr/local/pgsql/lib/libpostgis.so.0.8 failed: no error message
available
psql:postgis.sql:43: ERROR: current transaction is aborted, queries
ignored until end of transaction block
