[postgis-users] Postgis 0.8.0 QueryByRect Problem
strk
strk at keybit.net
Wed Dec 10 06:56:37 PST 2003
shpr wrote:
> Hi,
> when I do a querybyrect I receive the following error:
> Warning: [MapServer Error]: msPOSTGISLayerGetShape(): Error executing POSTGIS SQL statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d(the_geom)),'NDR') from (SELECT the_geom,gid,type,name,value from edtlyr_pozzi_1 WHERE site_id = 7799) as foo WHERE gid = 40716 -ERROR: cursor "mycursor" already exists
> More Help:
> Error with POSTGIS data variable. You specified ''.
> Standard ways of specifiying are :
> (1) 'geometry_column from geometry_table'
> (2) 'geometry_column from (<sub query>) as foo using unique <column name> using SRID=<srid#>'
> Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses in.
> I have just upgraded the software to:
> postgis 0.8.0, Mapserver 4.0.1, Postgres 7.4
> my previous platform was
> postgis 0.7.5 Mapserver 4.0, Postgres 7.3
> in this platform there were no problems.
> I see another question like this in the maling list but not answered. Is this a bug or something in changed in postgis 0.8.0.
> I have noticed that the problem appear only when I ask more than one object in the query.
> Thanks in advance.
> RS
I think the problem is in the postgis connector of Mapserver 4.0.1 -
It seems like it tries to open a cursor for each requested object
without closing it after use.
--strk;
