[postgis-users] Postgisdriver-1.0 is  not working.
    Justin Deoliveira
    jdeolive at refractions.net
    Wed Dec 10 07:55:32 PST 2003
Carlos, would it be possible for you to include the rest of the stack
trace. What you have included here only looks like a partial stack trace.
Also, it would be helpful to know which versions of Postgres/PostGIS you
are running. Thanks.
Justin
Carlos Ho Shih Ning wrote:
>Hello,
>As advertised on the Refractions website regarding to Postgisdriver-1.0
>"This JUMP 1.0 plug-in will provide basic support for reading and writing from a PostGIS database.
> Currently only JUMP 1.0 is supported"
>I used the two versions of JUMP (1.0 and 1.1) with the postgisdriver-1.0.zip from the
>http://postgis.refractions.net/download.php site. And in both cases
>I also included the postgresql.jar in the Jump/lib directory and
>an error message comes out
>java.lang.IllegalStateException: Expected ')' or ',' but encountered 'E-19' 	at net.refractions.postgis.PostGISConnection.executeQuery(PostGISConnection.java:179) 	at com.vividsolutions.jump.workbench.datasource.LoadDatasetPlugIn.run(Unknown Source) 	at com.vividsolutions.jump.workbench.ui.task.TaskMonitorManager$TaskWrapper.run(Unknown Source) 	at java.lang.Thread.run(Thread.java:536)
>Because the first error message requested an org.postgresql.Driver I tried the
>different available drivers (pg73jdbc3.jar, pg73jdbc2ee.jar, pg72jdbc1.jar,
>pg72jdbc2.jar, pg73jdbc2.jar) and none of the prevented the error above to come out.
>I would like to know if someone has ever succeeded in making Jump work with driver.
>If so which are the jar files that I need?
>thank you in advance
>Carlos
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
