[postgis-users] shp2pgsql and schemas
strk
strk at keybit.net
Thu Dec 11 01:05:50 PST 2003
I remember there has been discussions about this back this year :)
Check the archives...
--strk;
carrolls wrote:
> Hi,
> I have used shp2pgsql in a version released sometime before the summer and
> there used to be an arguement for the schema and the table.
> shp2pgsql for 0.8.0 does not have this option. I thought I could just
> input both piece of information in the table arguement ( schema.table )
> but this results in the error when loading the file using psql:
> NOTICE: CREATE TABLE will create implicit sequence "carrolls_route_alberta_test_gid_seq" for "serial" column "carrolls_route_alberta_test.gid"
> psql:toload.sql:1: NOTICE: CREATE TABLE will create implicit sequence "carrolls_route_alberta_test_gid_seq" for "serial" column "carrolls_route_alberta_test.gid"
> CREATE TABLE
> ERROR: relation "roads.carrolls_route_alberta_test" does not exist
> CONTEXT: PL/pgSQL function "addgeometrycolumn" line 38 at execute statement
> psql:toload.sql:2: ERROR: relation "roads.carrolls_route_alberta_test" does not exist
> BEGIN
> ERROR: column "the_geom" of relation "carrolls_route_alberta_test" does not exist
> psql:toload.sql:4: ERROR: column "the_geom" of relation "carrolls_route_alberta_test" does not exist
> ERROR: current transaction is aborted, commands ignored until end of transaction block
> and so on.
> What is the new technique for loading gis data into a schema other than
> public?
> Seamus
> postgis-users mailing list
