[postgis-users] problem with database upgrading
Jaakko Kahkonen
jaakko.kahkonen at fgi.fi
Wed Dec 17 07:25:49 PST 2003
Hello,
I would like to export database from old computer (RedHat Linux 7.2,
postgresql-postgis-7.1.3-1PGDG) and import it to new computer (Gentoo
Linux, postgresql-7.3.4, postgis-0.7.5). I'm trying to do it with
upgrading instructions at
http://postgis.refractions.net/docs/x83.html#AEN150 :
# pg_dump -t "*" -f dumpfile.sql yourdatabase
# dropdb yourdatabase
# createdb yourdatabase
# createlang plpgsql yourdatabse
# psql -f postgis.sql -d yourdatabase
# psql -f dumpfile.sql -d yourdatabase (problem with this!!)
# vacuumdb -z yourdatabase
When reading to the database, I get following:
bash-2.05b$ psql -f data_dump.sql -d testdata
You are now connected as new user jaska.
psql:data_dump.sql:17: NOTICE: CREATE TABLE / PRIMARY KEY will create
implicit index 'spa
al_ref_sys_pkey' for table 'spatial_ref_sys'
psql:data_dump.sql:17: ERROR: Relation 'spatial_ref_sys' already exists
psql:data_dump.sql:34: NOTICE: CREATE TABLE / PRIMARY KEY will create
implicit index 'gc_
' for table 'geometry_columns'
psql:data_dump.sql:34: ERROR: Relation 'geometry_columns' already exists
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
psql:data_dump.sql:399: ERROR: copy: line 1, Missing data for column
"attrelid"
psql:data_dump.sql:399: lost synchronization with server, resetting
connection
bash-2.05b$
Is there an easy and correct way to do this? I have original data as
shapefiles, so I can always use them. We have deleted a few lines from
database, so I decided to try without shapes at first.
Jaakko
