[postgis-users] postgis, postgresql and geological data
Philip Riggs priggs at cnr.colostate.edu
Wed Dec 17 09:00:31 PST 2003
I used to work for an environmental engineering firm and we kept this
sort of data in a database using GIS\Key, a horrible (unless they have
since improved it) system. But it kept borehole data (lat-long, depth
to water, substrate type and distance interval below surface) and you
could add any chemical analysis of water samples related to the
borehold id. USGS data is way too generalized to give the accuracy a
geologist records for each hole drilled. Before you go this route, you
should check on state accuracy requirements. The state may prefer no
data to bad data in this regard.
Philip D Riggs
