[postgis-users] Cygwin installation
Tyler Mitchell
TMitchell at lignum.com
Wed Dec 17 14:36:21 PST 2003
Congrats!
On the postgis support page (http://postgis.refractions.net/support.php)
there is a search box which searches the archives.
Tyler
"BLISS Meredith *
DAS CJC"
<Meredith.Bliss at s To
tate.or.us> "PostGIS Users Discussion"
Sent by: <postgis-users at postgis.refractions.
postgis-users-bou net>
nces at postgis.refr cc
actions.net
Fax to
12/16/2003 05:01 Subject
PM RE: [postgis-users] Cygwin
installation
Please respond to
PostGIS Users
Discussion
stgis.refractions
.net>
Hey, that worked! Seems crazy, but what do I know? But I'm curious how you
found that reference -- I couldn't see a search function in the archives.
Now the fun begins, learning MapServer all over again ...
Thanks,
--Bud
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Tyler
Mitchell
Sent: Tuesday, December 16, 2003 4:19 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Cygwin installation
I can't help you with the DCMMS issue, but I think the problem you first
mention is addressed at:
http://postgis.refractions.net/pipermail/postgis-users/2003-March/002263.html
Basically you need to change one line in a file and then run make again
(maybe "make clean" first).
I don't know, but I have a hunch that the latest version of postgis doesn't
have this problem (anyone know?). I just went through installing it and
don't remember having the problem.
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 12/16/2003 04:02:07
PM:
> Next problem(s): I tried to compile PostGIS, but make fails with
thefollowing:
> fu000001.o(.idata$3+0xc): undefined reference to `_libpostgres_a_iname'
> nmth000000.o(.idata$4+0x0): undefined reference to
> `__nm__cpu_index_tuple_cost'
> Info: resolving _cpu_index_tuple_cost by linking to
> __imp__cpu_index_tuple_cost
> (auto-import)
> collect2: ld returned 1 exit status
> dllwrap: gcc exited with status 1
> make: *** [libpostgis.a] Error 1
> after a couple of cycles of make clean / make, I tried the DCMMS
> PostGIS installer, which seemed to complete without a problem, but
> then when I try to do "psql -U postgres -d myGISdb -f postgis.sql" I get
> BEGIN
> message
> PL/PgSQL is installed.
> (1 row)
> psql:postgis.sql:41: NOTICE: ProcedureCreate: type histogram2d is
> not yet defined
> psql:postgis.sql:41: ERROR: Load of file
> /usr/lib/postgresql/postgis.dll failed: dlopen: Win32 error 127
> psql:postgis.sql:46: ERROR: current transaction is aborted, queries
> ignored until end of transaction block
> psql:postgis.sql:54: ERROR: current transaction is aborted, queries
> ignored until end of transaction block ... [many more similar lines
deleted]
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of BLISS
> Meredith * DAS CJC
> Sent: Tuesday, December 16, 2003 8:53 AM
> Thank you, chmod did the trick! Now it's on to PostGIS installation.
> I finally get somewhat comfortable using Linux, now I have to figure
> out mixed permissions in Windows+Cygwin. There seems to be no end of
> interesting challenges ...
> Steffen Macke
> Sent: Tuesday, December 16, 2003 4:47 AM
> Subject: Re: [postgis-users] Cygwin installation
> Meredith,
> eventually your postgres user does not have the right to run postgres.exe
> Could you try to fix the access rights with
> chmod a+rx /usr/bin/postgres.exe
> as the administrator of the machine
> and try again to run postgres.exe as the user postgres?
> If it still doesn't work, have a look at the postmaster log file
> c:\cygwin\var\log\postmaster.log
> This file might contain an error message that helps you to track down
> the problem.
> Steffen
> postgis-users mailing list
