[postgis-users] java libraries
TECHER Jean David
davidtecher at yahoo.fr
Tue Dec 30 03:07:19 PST 2003
> Hi:
> I have a question, What do you recommend? Geotools or Gistoolkit,
and do you have any example on How I have to use this libraries in order >
display the data in a web page or something similar.
Why don't you use MapServer? It let you display your data in a
webpage. Mapserver (version >= 3.6) can deal with PostGIS. You can go to
- http://mapserver.gis.umn.edu to download it
- http://postgis.refractions.net/docs/x556.html from PostGIS
documentation in order to use it with PostGIS.
Suppose that your table is 'geomtable', your database is 'myGIS' and
your user name is talledo
I ) you had to specifiy the extent of the image you want to display.
So do
select
xmin(extent(the_geom)),ymin(extent(the_geom)),xmax(extent(the_geom)),
ymax(extent(the_geom)) from geomtable
will give you 4 numbers: Xmin, Ymin, Xmax, Ymax. Suppose now that
you want an image with width=700. The height will be
height = 700 * abs(Ymax-Ymin)/abs(Xmax-Xmin)
II) In a file (for example) C:\mymap.map, put
MAP
IMAGETYPE PNG
EXTENT Xmin Ymin Xmax Ymax
SIZE 700 height
IMAGECOLOR 255 255 255
LAYER
NAME " mylayer "
CONNECTIONTYPE postgis
CONNECTION "user=talledo dbname=myGIS host=localhost"
DATA "the_geom from geomtable"
STATUS default
TYPE POLYGON
CLASS
COLOR 45 251 103
OUTLINECOLOR 255 0 0
LABEL
FORCE TRUE
POSITION CC
SIZE large
OUTLINECOLOR 255 255 0
BACKGROUNDCOLOR 255 255 204
BACKGROUNDSHADOWCOLOR 221 221 221
BACKGROUNDSHADOWSIZE 1 1
MINDISTANCE 2
COLOR 0 0 0
END #End of LABEL
END #End of Class
END #Layer
END
III) To display your data , type the URL
http://yourserver/cgi-bin/mapserv.exe?map=C:\mymap&mode=map
> This is because there are a lot of examples on how to display
data from a shape but I haven't found any example about How I can display
the data > using Postgis as my DB
> Thanks in Advance.
Gistoolkit (http://gistoolkit.sourceforge.net) can display data
from PostGIS. I''ve already tried Gistoolkit but I had to use others java
libraries in order to use it:batik....
TECHER Jean David
Tél: 06-85-37-36-75
e-mail: davidtecher at yahoo.fr
MSN Amor Busca tu ½ naranja
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20031230/95f76c68/attachment.html>
