[postgis-users] shp2pgsql and MULTIPOLYGONS in 0.7.3?
Sean Gillies sgillies at frii.com
Wed Feb 12 13:02:32 PST 2003
Thanks, Paul, I appreciate the recommendation.
However, I'm having trouble trying to build the cvs postGIS against
PostgreSQL 7.1.2.  I looked through the change logs and it looks
like pg 7.1 is still supported, but your code is looking for
stuff under 'utils' that doesn't come with 7.1.2.
Will I need 7.2 or 7.3 to build the newest PostGIS?
Sean
On Wednesday, February 12, 2003, at 11:36  AM, Paul Ramsey wrote:
> Get the CVS version, definately. The memory management bug which got
> squashed last week could cause very nondeterministic errors, which
> seems to be the sort of problem you are having.
> Sean Gillies wrote:
>> Hi,
>> A client of mine has been experiencing problems with shp2pgsql.  A
>> MULTIPOLYGON shapefile with 200 records never completely loads.
>> Sometimes it is 160 records, sometimes 170, sorta random.  Their
>> error is something about pg_read().  They are using the 0.7.0 release.
>> Is an upgrade to 0.7.3 going to help?
>> cheers,
>> Sean
>> Sean Gillies
>> http://www.frii.com/~sgillies
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>       __
>      | Paul Ramsey
>      | Refractions Research
>      | Email: pramsey at refractions.net
>      | Phone: (250) 885-0632
>      \_
