[postgis-users] shp2pgsql and MULTIPOLYGONS in 0.7.3?
Paul Ramsey
pramsey at refractions.net
Wed Feb 12 13:02:55 PST 2003
Simply delete postgis_estimate.o from the OBJs list, it is not needed in
7.1. I have also committed a fixed Makefile.
P.
Sean Gillies wrote:
> Thanks, Paul, I appreciate the recommendation.
> However, I'm having trouble trying to build the cvs postGIS against
> PostgreSQL 7.1.2. I looked through the change logs and it looks
> like pg 7.1 is still supported, but your code is looking for
> stuff under 'utils' that doesn't come with 7.1.2.
> Will I need 7.2 or 7.3 to build the newest PostGIS?
> Sean
> On Wednesday, February 12, 2003, at 11:36 AM, Paul Ramsey wrote:
>> Get the CVS version, definately. The memory management bug which got
>> squashed last week could cause very nondeterministic errors, which
>> seems to be the sort of problem you are having.
>> Sean Gillies wrote:
>>> Hi,
>>> A client of mine has been experiencing problems with shp2pgsql. A
>>> MULTIPOLYGON shapefile with 200 records never completely loads.
>>> Sometimes it is 160 records, sometimes 170, sorta random. Their
>>> error is something about pg_read(). They are using the 0.7.0 release.
>>> Is an upgrade to 0.7.3 going to help?
>>> cheers,
>>> Sean
>>> Sean Gillies
>>> sgillies at frii.com
>>> http://www.frii.com/~sgillies
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> __
>> | Paul Ramsey
>> | Refractions Research
>> | Email: pramsey at refractions.net
>> | Phone: (250) 885-0632
>> \_
__
| Paul Ramsey
\_
