[postgis-users] shp2pgsql and MULTIPOLYGONS in 0.7.3?
Sean Gillies
sgillies at frii.com
Wed Feb 12 13:23:39 PST 2003
Thanks again, Paul. Built without any problems.
cheers,
Sean
On Wednesday, February 12, 2003, at 02:02 PM, Paul Ramsey wrote:
> Simply delete postgis_estimate.o from the OBJs list, it is not needed
> in 7.1. I have also committed a fixed Makefile.
> P.
> Sean Gillies wrote:
>> Thanks, Paul, I appreciate the recommendation.
>> However, I'm having trouble trying to build the cvs postGIS against
>> PostgreSQL 7.1.2. I looked through the change logs and it looks
>> like pg 7.1 is still supported, but your code is looking for
>> stuff under 'utils' that doesn't come with 7.1.2.
>> Will I need 7.2 or 7.3 to build the newest PostGIS?
>> Sean
>> On Wednesday, February 12, 2003, at 11:36 AM, Paul Ramsey wrote:
>>> Get the CVS version, definately. The memory management bug which got
>>> squashed last week could cause very nondeterministic errors, which
>>> seems to be the sort of problem you are having.
>>> Sean Gillies wrote:
>>>> Hi,
>>>> A client of mine has been experiencing problems with shp2pgsql. A
>>>> MULTIPOLYGON shapefile with 200 records never completely loads.
>>>> Sometimes it is 160 records, sometimes 170, sorta random. Their
>>>> error is something about pg_read(). They are using the 0.7.0
>>>> release.
>>>> Is an upgrade to 0.7.3 going to help?
>>>> cheers,
>>>> Sean
>>>> Sean Gillies
>>>> http://www.frii.com/~sgillies
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> __
>>> | Paul Ramsey
>>> | Refractions Research
>>> | Email: pramsey at refractions.net
>>> | Phone: (250) 885-0632
>>> \_
> __
> | Paul Ramsey
> \_
