[postgis-users] Cygwin / PostgreSQL / PostGIS installation
Henry Holland hjholland at gmx.net
Mon Feb 24 06:04:59 PST 2003
List and Christian,
I am getting exactly the same results. Endless 'undefined' references in
the linking phase (I think). I've tried all sorts of combinations of
things that other users (thanks to Barbara Kastelliz for a brief moment
of hope:) and the archives have mentioned over the last two weeks to get
PostGIS 0.7.4 compiled and installed on Cygwin, but no luck.
I managed to install PostgreSQL from the source, but only without perl
(more 'undefined' references). I tried to install perl from source as
the latest cygwin perl binary package (5.6.1-2) is built with gcc2,
which I thought may be part of the problem. That was a complete
non-event (don't know how many times I've now gone through ./configure
and ./Configure scripts). Still no postgis. I've run out of ideas. If
anyone has any more suggestions (I would love to just do it all on
Linux, but I need it on WinXP), please let us know.
Regards,
Henry Holland
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of christian.schuster at rsag.ch
> Sent: 22 February 2003 12:18
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Cygwin / PostgreSQL / PostGIS installation
> Hi list,
> I have a working PostgreSQL with PostGIS (CVS) support on my
> local machine
> (Win2000 Pro). Now I have a new installed Win 2000 Server SP3 on a IBM
> Netfinity machine and I wanted to install there the latest releases of
> Cygwin, PostgreSQL and PostGIS. Here is the problem. I cannot make
> PostGIS-0.7.4. The error is:
> What I did is the following:
> 1.    I downloaded the latest cygwin release with PostgreSQL
> including the
> source:
> 2.    I added DLLIMPORT to /src/include/ptimizer/cost.h.
> 3.    I configured PostgreSQL LDFLAGS=-L/usr/local/lib ./configure
> 4.    I made PostgreSQL
>       Here I have many messages like the following on:
>          make -C tcop all
>          make[3]: Entering directory
>          `/usr/src/postgresql-7.3.2-1/src/backend/tcop'
>          gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations
>          -I../../../src/include  -DBUILDING_DLL  -c -o dest.o dest.c
>          -I../../../src/include  -DBUILDING_DLL  -c -o fastpath.o
>          fastpath.c
>          -I../../../src/include  -DBUILDING_DLL  -c -o postgres.o
>          postgres.c
> pquery.o pquery.c
> utility.o utility.c
>          /usr/i686-pc-cygwin/bin/ld.exe -r -o SUBSYS.o dest.o
> fastpath.o
>          postgres.o pquery.o utility.o
>          make[3]: Leaving directory
>       I just copied one out of them. But I guess something is not okay
>       But  was suprised as at the end message came that PostgreSQL was
> successfully made and is ready to install
>          /usr/include/stdio.h: At top level:
>          pl_scan.c:2384: warning: `yy_flex_realloc' defined
> but not used
>          -Wno-error  -I. -I../../../../src/include   -c -o
> pl_handler.o
>          pl_handler.c
>          -Wno-error  -I. -I../../../../src/include   -c -o pl_comp.o
>          pl_comp.c
>          -Wno-error  -I. -I../../../../src/include   -c -o pl_exec.o
>          pl_exec.c
>          -Wno-error  -I. -I../../../../src/include   -c -o pl_funcs.o
>          pl_funcs.c
>          dlltool --export-all --output-def plpgsql.def pl_gram.o
>          pl_handler.o pl_comp.o pl_exec.o pl_funcs.o
>          dllwrap -o plpgsql.dll --dllname plpgsql.dll --def
> plpgsql.def
>          pl_gram.o pl_handler.o pl_comp.o pl_exec.o pl_funcs.o
>          ../../../../src/utils/d
>          llinit.o -L/usr/local/lib -L../../../../src/backend
> -lpostgres
>          dlltool --dllname plpgsql.dll --def plpgsql.def --output-lib
>          libplpgsql.a
>          make[4]: Leaving directory
>          `/usr/src/postgresql-7.3.2-1/src/pl/plpgsql/src'
>          `/usr/src/postgresql-7.3.2-1/src/pl/plpgsql'
>          make[2]: Leaving directory
> `/usr/src/postgresql-7.3.2-1/src/pl'
>          make[1]: Leaving directory `/usr/src/postgresql-7.3.2-1/src'
>          All of PostgreSQL successfully made. Ready to install.
> 5.    I changed to the PostGIS directory and tried to make it with the
> following error:
>          $ make
> -Wmissing-declarations  -g -I.
>          -I../../src/include  -DFRONTEND
>          -DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUS
>          E_VERSION=73  -c -o postgis_debug.o postgis_debug.c
>          E_VERSION=73  -c -o postgis_ops.o postgis_ops.c
>          E_VERSION=73  -c -o postgis_fn.o postgis_fn.c
>          E_VERSION=73  -c -o postgis_inout.o postgis_inout.c
> postgis_estimate.o(.text+0x1380):/usr/src/postgresql-7.3.2-1/c
ontrib/postgis-0.7.4
> /postgis_estimate.c:743: undefined reference to `_nconc'
> postgis_estimate.o(.text+0x1388):/usr/src/postgresql-7.3.2-1/c
> /postgis_estimate.c:743: undefined reference to `_make_and
>          s_explicit'
> postgis_estimate.o(.text+0x1398):/usr/src/postgresql-7.3.2-1/c
> /postgis_estimate.c:745: undefined reference to `_canonica
>          lize_qual'
>          collect2: ld returned 1 exit status
>          dllwrap: gcc exited with status 1
>          make: *** [libpostgis.a] Error 1
> I looked in the archive of PostgreSQL and PostGIS and tried
> several things.
> But I was not able to figure out what I am doing wrong now.
> Does anyone knwo where I do the mistake or what I forgot?
> Regards,
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
http://www.rsag.ch
++41 31 348 05 30
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
