[postgis-users] Cygwin / PostgreSQL / PostGIS installation
Henry Holland
hjholland at gmx.net
Tue Feb 25 03:18:12 PST 2003
Christian,
Thanks. I tried your first solution and it worked. Finally! :)
> question. Did you
> also install the package Perl in Cygwin?
Yes, I installed the binary. I've had no luck trying to install it from
the source, and no-one's been able to help me on the lists (perl and
cygwin lists) either. I can install Postgresql from source if I don't
use perl (or any of the other extensions), but if I use --with-perl I
get more undefined references. Now, if postgis works with the binary
postgresql, perhaps I can use it as is and won't have to worry too much
since the binary is compiled with perl and java. I'll let you know if I
have any more trouble.
Thanks again.
Henry
> -----Original Message-----
> From: christian.schuster at rsag.ch [mailto:christian.schuster at rsag.ch]
> Sent: 24 February 2003 16:59
> To: hjholland at gmx.net; PostGIS Users Discussion
> Cc: 'PostGIS Users Discussion';
> postgis-users-bounces at postgis.refractions.net
> Subject: RE: [postgis-users] Cygwin / PostgreSQL / PostGIS
> installation
> I found two solutions for building and installing PostGIS.
> 1. Change in the Makefile like following
> # Add libraries that libpq depends (or might depend) on into the
> # shared library link. (The order in which you list them here doesn't
> # matter.)
> #SHLIB_LINK=$(filter -L%, $(LDFLAGS))
> ifeq ($(USE_PROJ),1)
> SHLIB_LINK=$(filter -L%, $(LDFLAGS)) -L$(PROJ_DIR)/lib -lproj
> else
> ../../src/backend/libpostgres.a
> endif
> 2. Change the Makefile like following
> # Select proper GiST support C file
> ifeq ($(USE_VERSION),71)
> GIST_SUPPORT=71
> GIST_ESTIMATE=
> else
> GIST_SUPPORT=72
> GIST_ESTIMATE= #postgis_estimate.o
> endif
> OBJS=postgis_debug.o postgis_ops.o postgis_fn.o postgis_inout.o
> postgis_proj.o postgis_chip.o postgis_transform.o
> postgis_gist_$(GIST_SUPPORT).o $(GIST_ESTIMATE)
> # matter.)
> else
> endif
> Henry, I just installed PostgreSQL. I configure PostgreSQL
> just like this
> ./configure --with-java. I did not have any troubles. One
> question. Did you
> Can you send me a print of your ./configure or make output? I
> am really not
> an expert in all of these topics. But I spent already many
> hours on it. It
> may be that I can help you.
> Regards,
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
> "Henry Holland"
> <hjholland at gmx.ne
> t>
> To
> Sent by: "'PostGIS Users
> Discussion'"
> postgis-users-bou
> <postgis-users at postgis.refractions.
> nces at postgis.refr net>
> actions.net
> cc
> Subject
> 24.02.2003 15:04 RE: [postgis-users]
> Cygwin /
> installation
> Please respond to
> ; Please respond
> to
> PostGIS Users
> Discussion
> stgis.refractions
> .net>
> List and Christian,
> I am getting exactly the same results. Endless 'undefined'
> references in
> the linking phase (I think). I've tried all sorts of combinations of
> things that other users (thanks to Barbara Kastelliz for a
> brief moment
> of hope:) and the archives have mentioned over the last two
> weeks to get
> PostGIS 0.7.4 compiled and installed on Cygwin, but no luck.
> I managed to install PostgreSQL from the source, but only without perl
> (more 'undefined' references). I tried to install perl from source as
> the latest cygwin perl binary package (5.6.1-2) is built with gcc2,
> which I thought may be part of the problem. That was a complete
> non-event (don't know how many times I've now gone through ./configure
> and ./Configure scripts). Still no postgis. I've run out of ideas. If
> anyone has any more suggestions (I would love to just do it all on
> Linux, but I need it on WinXP), please let us know.
> Regards,
> Henry Holland
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of christian.schuster at rsag.ch
> > Sent: 22 February 2003 12:18
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Cygwin / PostgreSQL / PostGIS installation
> > Hi list,
> > I have a working PostgreSQL with PostGIS (CVS) support on my
> > local machine
> > (Win2000 Pro). Now I have a new installed Win 2000 Server
> SP3 on a IBM
> > Netfinity machine and I wanted to install there the latest
> releases of
> > Cygwin, PostgreSQL and PostGIS. Here is the problem. I cannot make
> > PostGIS-0.7.4. The error is:
> > What I did is the following:
> > 1. I downloaded the latest cygwin release with PostgreSQL
> > including the
> > source:
> > 2. I added DLLIMPORT to /src/include/ptimizer/cost.h.
> > 3. I configured PostgreSQL LDFLAGS=-L/usr/local/lib ./configure
> > 4. I made PostgreSQL
> > Here I have many messages like the following on:
> > make -C tcop all
> > make[3]: Entering directory
> > `/usr/src/postgresql-7.3.2-1/src/backend/tcop'
> > gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations
> > -I../../../src/include -DBUILDING_DLL -c -o dest.o dest.c
> > -I../../../src/include -DBUILDING_DLL -c -o fastpath.o
> > fastpath.c
> > -I../../../src/include -DBUILDING_DLL -c -o postgres.o
> > postgres.c
> > pquery.o pquery.c
> > utility.o utility.c
> > /usr/i686-pc-cygwin/bin/ld.exe -r -o SUBSYS.o dest.o
> > fastpath.o
> > postgres.o pquery.o utility.o
> > make[3]: Leaving directory
> > I just copied one out of them. But I guess something
> is not okay
> > But was suprised as at the end message came that
> PostgreSQL was
> > successfully made and is ready to install
> > /usr/include/stdio.h: At top level:
> > pl_scan.c:2384: warning: `yy_flex_realloc' defined
> > but not used
> > -Wno-error -I. -I../../../../src/include -c -o
> > pl_handler.o
> > pl_handler.c
> > -Wno-error -I. -I../../../../src/include -c -o pl_comp.o
> > pl_comp.c
> > -Wno-error -I. -I../../../../src/include -c -o pl_exec.o
> > pl_exec.c
> pl_funcs.o
> > pl_funcs.c
> > dlltool --export-all --output-def plpgsql.def pl_gram.o
> > pl_handler.o pl_comp.o pl_exec.o pl_funcs.o
> > dllwrap -o plpgsql.dll --dllname plpgsql.dll --def
> > plpgsql.def
> > pl_gram.o pl_handler.o pl_comp.o pl_exec.o pl_funcs.o
> > ../../../../src/utils/d
> > llinit.o -L/usr/local/lib -L../../../../src/backend
> > -lpostgres
> > dlltool --dllname plpgsql.dll --def plpgsql.def
> --output-lib
> > libplpgsql.a
> > make[4]: Leaving directory
> > `/usr/src/postgresql-7.3.2-1/src/pl/plpgsql/src'
> > `/usr/src/postgresql-7.3.2-1/src/pl/plpgsql'
> > make[2]: Leaving directory
> > `/usr/src/postgresql-7.3.2-1/src/pl'
> > make[1]: Leaving directory
> `/usr/src/postgresql-7.3.2-1/src'
> > All of PostgreSQL successfully made. Ready to install.
> > 5. I changed to the PostGIS directory and tried to make
> it with the
> > following error:
> > $ make
> > -Wmissing-declarations -g -I.
> > -I../../src/include -DFRONTEND
> > -DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUS
> > E_VERSION=73 -c -o postgis_debug.o postgis_debug.c
> > E_VERSION=73 -c -o postgis_ops.o postgis_ops.c
> > E_VERSION=73 -c -o postgis_fn.o postgis_fn.c
> > E_VERSION=73 -c -o postgis_inout.o postgis_inout.c
> > postgis_estimate.o(.text+0x1380):/usr/src/postgresql-7.3.2-1/c
> ontrib/postgis-0.7.4
> > /postgis_estimate.c:743: undefined reference to `_nconc'
> > postgis_estimate.o(.text+0x1388):/usr/src/postgresql-7.3.2-1/c
> > /postgis_estimate.c:743: undefined reference to `_make_and
> > s_explicit'
> > postgis_estimate.o(.text+0x1398):/usr/src/postgresql-7.3.2-1/c
> > /postgis_estimate.c:745: undefined reference to `_canonica
> > lize_qual'
> > collect2: ld returned 1 exit status
> > dllwrap: gcc exited with status 1
> > make: *** [libpostgis.a] Error 1
> > I looked in the archive of PostgreSQL and PostGIS and tried
> > several things.
> > But I was not able to figure out what I am doing wrong now.
> > Does anyone knwo where I do the mistake or what I forgot?
> > Regards,
> > Christian Schuster
> > Rudolf Schuster AG
> > Postfach 277
> > CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
> postgis-users mailing list
