Thanks! RE: [postgis-users] Cygwin / PostgreSQL / PostGIS installation
Henry Holland
hjholland at gmx.net
Wed Feb 26 00:39:47 PST 2003
Thanks for all the help from this list. It's been a frustrating couple
of days but I've got Postgis installed and running. I'll now get onto
designing my spatial database and am sure I'll have more queries.
Hopefully, though, they'll be a bit more interesting.
Best regards,
Henry
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Norman Vine
> Sent: 25 February 2003 14:59
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Cygwin / PostgreSQL / PostGIS
> installation
> Henry Holland writes:
> > > question. Did you
> > > also install the package Perl in Cygwin?
> > Yes, I installed the binary. I've had no luck trying to
> install it from
> > the source, and no-one's been able to help me on the lists (perl and
> > cygwin lists) either. I can install Postgresql from source
> if I don't
> > use perl (or any of the other extensions), but if I use
> --with-perl I
> > get more undefined references. Now, if postgis works with the binary
> > postgresql, perhaps I can use it as is and won't have to
> worry too much
> > since the binary is compiled with perl and java. I'll let
> you know if I
> > have any more trouble.
> FYI - the following snipped from
> /usr/src/$POSTGRES/CYGWIN-PATCHES/README
> The following packages or later are required to build and/or execute
> Cygwin PostgreSQL:
> perl 5.8.0-1
> this works for me
> Norman
> postgis-users mailing list
