[postgis-users] postgis installation problem
Strobl, Christian
Christian.Strobl at gla.bayern.de
Wed Feb 26 11:25:02 PST 2003
hello,
Hello, I tried to install postgis under cygwin/Windows 2000, following the
"NON-UNIX User's Guide". Everything worked fine and I had no problems with
configure and make of Postgres. But now make of postgis shows a lot of
undefined references. I added also the PGSQL_SRC-Variable to the makefile.
Any idea what to do? I am no c-programmer at all.
thanks and greetings from munich
christian
i get always this error-message (its a little bit long):
postgis_debug.o(.text+0x2e0): In function `mem_size':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_debug.c:101: undefined
reference to `_pg_detoast_datum'
postgis_debug.o(.text+0x310): In function `numb_sub_objs':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_debug.c:110: undefined
postgis_debug.o(.text+0x40d): In function `summary':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_debug.c:119: undefined
postgis_debug.o(.text+0x418):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:132: undefined reference to `__imp__CurrentMemoryContext'
postgis_debug.o(.text+0x430):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:132: undefined reference to `_MemoryContextAlloc'
postgis_debug.o(.text+0x49e):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:180: undefined reference to `__imp__CurrentMemoryContext'
postgis_debug.o(.text+0x4af):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:180: undefined reference to `_MemoryContextAlloc'
postgis_debug.o(.text+0x4e1):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:183: undefined reference to `_pfree'
postgis_debug.o(.text+0x52e):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:168: undefined reference to `_repalloc'
postgis_debug.o(.text+0x5e5):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:158: undefined reference to `_repalloc'
postgis_debug.o(.text+0x645):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_debug.c:148: undefined reference to `_repalloc'
postgis_debug.o(.text+0x14e8): In function `print_geometry':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_debug.c:726: undefined
reference to `_DirectFunctionCall1'
postgis_ops.o(.text+0x15): In function `make_bvol_geometry':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:46: undefined
postgis_ops.o(.text+0x156): In function `geometry_overleft':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:79: undefined
postgis_ops.o(.text+0x163):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:80: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x181):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:90: undefined reference to `_elog'
postgis_ops.o(.text+0x1f6): In function `geometry_left':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:102: undefined
postgis_ops.o(.text+0x203):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:103: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x221):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:111: undefined reference to `_elog'
postgis_ops.o(.text+0x296): In function `geometry_right':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:126: undefined
postgis_ops.o(.text+0x2a3):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:127: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x2c1):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:134: undefined reference to `_elog'
postgis_ops.o(.text+0x336): In function `geometry_overright':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:147: undefined
postgis_ops.o(.text+0x343):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:148: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x361):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:155: undefined reference to `_elog'
postgis_ops.o(.text+0x3d6): In function `geometry_contained':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:170: undefined
postgis_ops.o(.text+0x3e3):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:171: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x401):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:177: undefined reference to `_elog'
postgis_ops.o(.text+0x4d6): In function `geometry_contain':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:197: undefined
postgis_ops.o(.text+0x4e3):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:198: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x501):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:205: undefined reference to `_elog'
postgis_ops.o(.text+0x6c6): In function `geometry_overlap':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:246: undefined
postgis_ops.o(.text+0x6d3):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:247: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x6f1):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:253: undefined reference to `_elog'
postgis_ops.o(.text+0x866): In function `geometry_lt':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:290: undefined
postgis_ops.o(.text+0x873):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:291: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x891):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:296: undefined reference to `_elog'
postgis_ops.o(.text+0x956): In function `geometry_gt':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:331: undefined
postgis_ops.o(.text+0x963):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:332: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x981):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:337: undefined reference to `_elog'
postgis_ops.o(.text+0xa56): In function `geometry_eq':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:371: undefined
postgis_ops.o(.text+0xa63):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:372: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0xa81):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:376: undefined reference to `_elog'
postgis_ops.o(.text+0xbd9): In function `geometry_same':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:443: undefined
postgis_ops.o(.text+0xbe6):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:444: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0xc04):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:455: undefined reference to `_elog'
postgis_ops.o(.text+0xc3e):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:473: undefined reference to `_DirectFunctionCall2'
postgis_ops.o(.text+0xc50):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:485: undefined reference to `__imp__CurrentMemoryContext'
postgis_ops.o(.text+0xc61):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:485: undefined reference to `_MemoryContextAlloc'
postgis_ops.o(.text+0xf73): In function `geometry_union':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:623: undefined
postgis_ops.o(.text+0xf83):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:624: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0xf8a):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:625: undefined reference to `__imp__CurrentMemoryContext'
postgis_ops.o(.text+0xf9c):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:625: undefined reference to `_MemoryContextAlloc'
postgis_ops.o(.text+0xfba):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_ops.c:630: undefined reference to `_elog'
postgis_ops.o(.text+0x10e3):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:657: undefined reference to `_pfree'
postgis_ops.o(.text+0x10f3):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:658: undefined reference to `_pfree'
postgis_ops.o(.text+0x1183): In function `geometry_inter':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:666: undefined
postgis_ops.o(.text+0x1193):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:667: undefined reference to `_pg_detoast_datum'
postgis_ops.o(.text+0x119a):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:668: undefined reference to `__imp__CurrentMemoryContext'
postgis_ops.o(.text+0x11ac):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:668: undefined reference to `_MemoryContextAlloc'
postgis_ops.o(.text+0x11ca):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:672: undefined reference to `_elog'
postgis_ops.o(.text+0x1309):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:694: undefined reference to `_pfree'
postgis_ops.o(.text+0x1319):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:698: undefined reference to `_pfree'
postgis_ops.o(.text+0x1329):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:699: undefined reference to `_pfree'
postgis_ops.o(.text+0x13cd): In function `geometry_size':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_ops.c:720: undefined
postgis_ops.o(.text+0x1400):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_ops.c:736: undefined reference to `_pfree'
postgis_fn.o(.text+0x175): In function `length3d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:116: undefined
postgis_fn.o(.text+0x1aa):/usr/share/postgresql/contrib/postgis-0.7.4/postgi
s_fn.c:138: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x205): In function `length2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:150: undefined
postgis_fn.o(.text+0x23a):/usr/share/postgresql/contrib/postgis-0.7.4/postgi
s_fn.c:172: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x385): In function `area2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:224: undefined
postgis_fn.o(.text+0x3ba):/usr/share/postgresql/contrib/postgis-0.7.4/postgi
s_fn.c:245: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x605): In function `perimeter3d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:334: undefined
postgis_fn.o(.text+0x63a):/usr/share/postgresql/contrib/postgis-0.7.4/postgi
s_fn.c:355: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x695): In function `perimeter2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:362: undefined
postgis_fn.o(.text+0x6ca):/usr/share/postgresql/contrib/postgis-0.7.4/postgi
s_fn.c:383: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0xe13): In function `truly_inside':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:696: undefined
postgis_fn.o(.text+0xe20):/usr/share/postgresql/contrib/postgis-0.7.4/postgi
s_fn.c:697: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0xe3e):/usr/share/postgresql/contrib/postgis-0.7.4/postgi
s_fn.c:708: undefined reference to `_elog'
postgis_fn.o(.text+0xf37): In function `npoints':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:754: undefined
postgis_fn.o(.text+0xfe5): In function `nrings':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:799: undefined
postgis_fn.o(.text+0x10b3): In function `translate':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:853: undefined
postgis_fn.o(.text+0x10cf):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:871: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x10e2):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:871: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x1279): In function `force_2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:931: undefined
postgis_fn.o(.text+0x1280):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:934: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x1290):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:934: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x1309): In function `force_3d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:945: undefined
postgis_fn.o(.text+0x1310):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:948: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x1320):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:948: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x13a3): In function `combine_bbox':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:996: undefined
postgis_fn.o(.text+0x13b5):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:996: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x13c6):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:999: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x1511):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:987: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x1523):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:987: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x1548):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:977: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x154f):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:979: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x1564):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:979: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x15a0): In function `dimension':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1031: undefined
postgis_fn.o(.text+0x15e2): In function `geometrytype':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1043: undefined
postgis_fn.o(.text+0x15e9):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1044: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x15fb):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1044: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x17cb): In function `envelope':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1090: undefined
postgis_fn.o(.text+0x1993): In function `x_point':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1121: undefined
postgis_fn.o(.text+0x19dc):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1138: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x1a13): In function `y_point':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1150: undefined
postgis_fn.o(.text+0x1a5d):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1167: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x1a93): In function `z_point':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1179: undefined
postgis_fn.o(.text+0x1add):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1196: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x1b13): In function `numpoints_linestring':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1209: undefined
postgis_fn.o(.text+0x1b83): In function `pointn_linestring':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1238: undefined
postgis_fn.o(.text+0x1c73): In function `exteriorring_polygon':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1277: undefined
postgis_fn.o(.text+0x1d43): In function `numinteriorrings_polygon':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1322: undefined
postgis_fn.o(.text+0x1db3): In function `interiorringn_polygon':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1355: undefined
postgis_fn.o(.text+0x1ec3):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1412: more undefined references to `_pg_detoast_datum' follow
postgis_fn.o(.text+0x2060): In function `force_collection':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1497: undefined
postgis_fn.o(.text+0x2070):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1497: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x20e5): In function `point_inside_circle':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1514: undefined
postgis_fn.o(.text+0x2b0c): In function `distance_pt_poly':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1801: undefined
postgis_fn.o(.text+0x2bab): In function `distance_line_poly':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1831: undefined
postgis_fn.o(.text+0x2dbb): In function `distance_poly_poly':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1945: undefined
postgis_fn.o(.text+0x2e43): In function `distance':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:1969: undefined
postgis_fn.o(.text+0x2e51):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1970: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x2e7e):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:1981: undefined reference to `_elog'
postgis_fn.o(.text+0x2f9f):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2056: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x3145): In function `expand_bbox':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2067: undefined
postgis_fn.o(.text+0x315a):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2067: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x31c3): In function `startpoint':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2089: undefined
postgis_fn.o(.text+0x3263): In function `endpoint':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2117: undefined
postgis_fn.o(.text+0x3313): In function `isclosed':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2154: undefined
postgis_fn.o(.text+0x33d3): In function `centroid':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2181: undefined
postgis_fn.o(.text+0x3486):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2222: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x349e):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2222: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x352b):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2229: undefined reference to `_pfree'
postgis_fn.o(.text+0x3589): In function `max_distance':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2245: undefined
postgis_fn.o(.text+0x3596):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2246: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x35b4):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2259: undefined reference to `_elog'
postgis_fn.o(.text+0x3647):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2289: undefined reference to `_Float8GetDatum'
postgis_fn.o(.text+0x3779): In function `optimistic_overlap':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2300: undefined
postgis_fn.o(.text+0x3786):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2301: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x37ab):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2308: undefined reference to `_elog'
postgis_fn.o(.text+0x3896):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2348: undefined reference to `_DirectFunctionCall2'
postgis_fn.o(.text+0x38ef): In function `segmentize_ring':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2369: undefined
postgis_fn.o(.text+0x390a):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2369: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x3a54):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2390: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x3a6f):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2390: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x3a91):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2393: undefined reference to `_pfree'
postgis_fn.o(.text+0x3b06): In function `segmentize':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2428: undefined
postgis_fn.o(.text+0x3b40):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2449: undefined reference to `_elog'
postgis_fn.o(.text+0x3b88):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2462: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x3b9a):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2462: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x3bae):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2466: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x3bc6):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2466: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x3c52):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2492: undefined reference to `_pfree'
postgis_fn.o(.text+0x3d04):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2502: undefined reference to `_pfree'
postgis_fn.o(.text+0x3d0f):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2503: undefined reference to `_pfree'
postgis_fn.o(.text+0x3d73):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2510: undefined reference to `_pfree'
postgis_fn.o(.text+0x3d7e):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2511: undefined reference to `_pfree'
postgis_fn.o(.text+0x3d8f):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2513: more undefined references to `_pfree' follow
postgis_fn.o(.text+0x3da1): In function `segmentize':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2484: undefined
postgis_fn.o(.text+0x3db9):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2484: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x3df4):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2487: undefined reference to `_pfree'
postgis_fn.o(.text+0x3e46): In function `collector':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2562: undefined
postgis_fn.o(.text+0x3e54):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2563: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x3e75):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2566: undefined reference to `_elog'
postgis_fn.o(.text+0x3e91):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2569: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x3ea4):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2569: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x3f34):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2585: undefined reference to `_pfree'
postgis_fn.o(.text+0x3f76):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2592: undefined reference to `_pfree'
postgis_fn.o(.text+0x3fa4):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2556: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x3fac):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2557: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x3fbf):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2557: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x400c):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2547: undefined reference to `_pg_detoast_datum'
postgis_fn.o(.text+0x4013):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2548: undefined reference to `__imp__CurrentMemoryContext'
postgis_fn.o(.text+0x4025):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2548: undefined reference to `_MemoryContextAlloc'
postgis_fn.o(.text+0x4069): In function `box3d_xmin':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2602: undefined
postgis_fn.o(.text+0x40aa): In function `box3d_ymin':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2610: undefined
postgis_fn.o(.text+0x40ea): In function `box3d_zmin':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2618: undefined
postgis_fn.o(.text+0x412a): In function `box3d_xmax':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2626: undefined
postgis_fn.o(.text+0x416a): In function `box3d_ymax':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_fn.c:2634: undefined
postgis_fn.o(.text+0x41aa):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_fn.c:2642: more undefined references to `_Float8GetDatum' follow
postgis_inout.o(.text+0x477): In function `parse_points_in_list':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:245: undefined
postgis_inout.o(.text+0x7f9): In function `parse_box3d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:505: undefined
postgis_inout.o(.text+0x80e):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:505: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x856):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:520: undefined reference to `_elog'
postgis_inout.o(.text+0x85e):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:538: undefined reference to `_pfree'
postgis_inout.o(.text+0x925):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:537: undefined reference to `_elog'
postgis_inout.o(.text+0x9e7): In function `box3d_out':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:594: undefined
postgis_inout.o(.text+0x9f9):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:594: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0xa71):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:588: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0xa83):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:588: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0xda1): In function `parse_objects_inside_point':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:779: undefined
postgis_inout.o(.text+0xdb3):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:779: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0xeb0): In function `parse_objects_inside_multipoint':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:825: undefined
postgis_inout.o(.text+0xec6):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:825: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0xf4e):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:850: undefined reference to `_pfree'
postgis_inout.o(.text+0xf67):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:841: undefined reference to `_pfree'
postgis_inout.o(.text+0xf76):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:828: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0xf8a):/usr/share/postgresql/contrib/postgis-0.7.4/pos
tgis_inout.c:828: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x103d): In function `parse_objects_inside_line':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:883: undefined
postgis_inout.o(.text+0x105a):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:883: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x1305): In function `parse_objects_inside_polygon':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:991: undefined
postgis_inout.o(.text+0x131b):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:991: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x1364):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1015: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x137b):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1015: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x14d6):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1085: undefined reference to `_pfree'
postgis_inout.o(.text+0x14ef):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1069: undefined reference to `_pfree'
postgis_inout.o(.text+0x1508):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1068: undefined reference to `_elog'
postgis_inout.o(.text+0x152e):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1003: undefined reference to `_elog'
postgis_inout.o(.text+0x196a): In function `bbox_of_point':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1223: undefined
postgis_inout.o(.text+0x197f):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1223: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x1cd8): In function `union_box3d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1328: undefined
postgis_inout.o(.text+0x1cea):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1328: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x1d97): In function `bbox_of_geometry':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1396: undefined
postgis_inout.o(.text+0x1dc7):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1388: undefined reference to `_pfree'
postgis_inout.o(.text+0x1e07):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1380: undefined reference to `_pfree'
postgis_inout.o(.text+0x1e43): In function `geometry_from_text':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1408: undefined
postgis_inout.o(.text+0x1e4d):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1413: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x1e63):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1413: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x2087): In function `geometry_in':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1476: undefined
postgis_inout.o(.text+0x20e4):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1511: undefined reference to `_elog'
postgis_inout.o(.text+0x2145):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1530: undefined reference to `_elog'
postgis_inout.o(.text+0x2181):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1561: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x2195):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1561: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x21c5):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1564: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x21d9):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1564: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x2209):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1567: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x221d):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1567: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x22b1):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1618: undefined reference to `_pfree'
postgis_inout.o(.text+0x22bc):/usr/share/postgresql/contrib/postgis-0.7.4/po
postgis_inout.o(.text+0x22c7):/usr/share/postgresql/contrib/postgis-0.7.4/po
postgis_inout.o(.text+0x22e3):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1586: undefined reference to `_pfree'
postgis_inout.o(.text+0x2349):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1616: undefined reference to `_pfree'
postgis_inout.o(.text+0x2359):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1625: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x2367):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1625: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x23be):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1688: undefined reference to `_pfree'
postgis_inout.o(.text+0x23c9):/usr/share/postgresql/contrib/postgis-0.7.4/po
postgis_inout.o(.text+0x23d4):/usr/share/postgresql/contrib/postgis-0.7.4/po
postgis_inout.o(.text+0x23fb):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1697: undefined reference to `_pfree'
postgis_inout.o(.text+0x247a):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1678: undefined reference to `_pfree'
postgis_inout.o(.text+0x2543):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1494: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x2557):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1494: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x25b6):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1504: undefined reference to `_pfree'
postgis_inout.o(.text+0x25f0): In function `srid_geom':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1714: undefined
postgis_inout.o(.text+0x2633): In function `geometry_out':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1725: undefined
postgis_inout.o(.text+0x2650):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1735: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x265e):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1735: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x269a):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1740: undefined reference to `_pfree'
postgis_inout.o(.text+0x26d9): In function `astext_geometry':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1750: undefined
postgis_inout.o(.text+0x26f6):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1760: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x2704):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1760: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x2729):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1765: undefined reference to `_pfree'
postgis_inout.o(.text+0x27b1): In function `geometry_to_text':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1797: undefined
postgis_inout.o(.text+0x27cf):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1797: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x28e4):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1921: undefined reference to `_repalloc'
postgis_inout.o(.text+0x2969):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1955: undefined reference to `_repalloc'
postgis_inout.o(.text+0x2aaa):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1927: undefined reference to `_repalloc'
postgis_inout.o(.text+0x2aea):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1884: undefined reference to `_repalloc'
postgis_inout.o(.text+0x2bb0):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1903: undefined reference to `_repalloc'
postgis_inout.o(.text+0x2c38):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1853: more undefined references to `_repalloc' follow
postgis_inout.o(.text+0x2df3): In function `geometry_to_text':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:1802: undefined
postgis_inout.o(.text+0x2df8):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1803: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x2e0a):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:1803: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x2ea9): In function `get_bbox_of_geometry':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2000: undefined
postgis_inout.o(.text+0x2eb0):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2006: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x2ec5):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2006: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x2f13): In function `get_geometry_of_bbox':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2023: undefined
postgis_inout.o(.text+0x2f25):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2023: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x2fcd): In function `wkb_point':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2077: undefined
postgis_inout.o(.text+0x2fdd):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2077: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x311c): In function `wkb_multipoint':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2132: undefined
postgis_inout.o(.text+0x312c):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2132: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3432): In function `wkb_line':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2204: undefined
postgis_inout.o(.text+0x3445):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2204: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x351f): In function `wkb_multiline':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2298: undefined
postgis_inout.o(.text+0x352d):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2298: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x395b): In function `wkb_polygon':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2368: undefined
postgis_inout.o(.text+0x396e):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2368: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3a41): In function `wkb_multipolygon':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2512: undefined
postgis_inout.o(.text+0x3a4f):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2512: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3b4e): In function `to_wkb':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2564: undefined
postgis_inout.o(.text+0x3b65):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2564: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3b8d):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2567: undefined reference to `_pfree'
postgis_inout.o(.text+0x3bf7): In function `to_wkb_collection':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2626: undefined
postgis_inout.o(.text+0x3c05):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2626: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3c10):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2627: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x3c24):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2627: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3c6c):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2660: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x3c80):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2660: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3ce4):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2693: undefined reference to `_pfree'
postgis_inout.o(.text+0x3cef):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2694: undefined reference to `_pfree'
postgis_inout.o(.text+0x3d3f):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2688: undefined reference to `_pfree'
postgis_inout.o(.text+0x3f01): In function `to_wkb_sub':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2803: undefined
postgis_inout.o(.text+0x3f15):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2803: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x3fb1):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2783: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x3fc5):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2783: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4110): In function `asbinary_simple':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2828: undefined
postgis_inout.o(.text+0x416e): In function `asbinary_specify':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2844: undefined
postgis_inout.o(.text+0x417c):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2845: undefined reference to `_pg_detoast_datum'
postgis_inout.o(.text+0x41f6): In function `geometry_text':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2869: undefined
postgis_inout.o(.text+0x4202):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2878: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x4212):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2878: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4246):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2883: undefined reference to `_DirectFunctionCall1'
postgis_inout.o(.text+0x4286): In function `make_oneobj_geometry':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:2906: undefined
postgis_inout.o(.text+0x42a6):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2906: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4357):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:2931: undefined reference to `_pfree'
postgis_inout.o(.text+0x4448): In function `add_to_geometry':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3003: undefined
postgis_inout.o(.text+0x445a):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3003: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4682): In function `make_polygon':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3110: undefined
postgis_inout.o(.text+0x4690):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3110: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4738): In function `make_line':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3142: undefined
postgis_inout.o(.text+0x4746):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3142: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4c07): In function `WKB_in':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3400: undefined
postgis_inout.o(.text+0x4c68):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3410: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x4c84):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3410: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4ce5): In function `WKB_out':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3425: undefined
postgis_inout.o(.text+0x4cee):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3433: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x4d00):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3433: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4d73): In function `WKBtoBYTEA':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3447: undefined
postgis_inout.o(.text+0x4d7a):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3450: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x4d8a):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3450: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x4e00): In function `geometry2box':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3459: undefined
postgis_inout.o(.text+0x4eaa): In function `create_histogram2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3480: undefined
postgis_inout.o(.text+0x4ed0):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3487: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x4ede):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3487: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x51a6): In function `histogram2d_in':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3536: undefined
postgis_inout.o(.text+0x5280):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3568: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x529b):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3568: undefined reference to `_MemoryContextAlloc'
postgis_inout.o(.text+0x53d8): In function `histogram2d_out':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_inout.c:3604: undefined
postgis_inout.o(.text+0x53de):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3611: undefined reference to `__imp__CurrentMemoryContext'
postgis_inout.o(.text+0x53fe):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_inout.c:3611: undefined reference to `_MemoryContextAlloc'
postgis_proj.o(.text+0xe0): In function `ellipsoid_in':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_proj.c:40: undefined
postgis_proj.o(.text+0xf2):/usr/share/postgresql/contrib/postgis-0.7.4/postg
is_proj.c:40: undefined reference to `_MemoryContextAlloc'
postgis_proj.o(.text+0x12a):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:49: undefined reference to `_elog'
postgis_proj.o(.text+0x132):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:62: undefined reference to `_pfree'
postgis_proj.o(.text+0x253): In function `ellipsoid_out':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_proj.c:83: undefined
postgis_proj.o(.text+0x265):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:83: undefined reference to `_MemoryContextAlloc'
postgis_proj.o(.text+0xa43): In function `length_ellipsoid':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_proj.c:269: undefined
postgis_proj.o(.text+0xa8a):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:293: undefined reference to `_Float8GetDatum'
postgis_proj.o(.text+0xae3): In function `length3d_ellipsoid':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_proj.c:311: undefined
postgis_proj.o(.text+0xb2a):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:335: undefined reference to `_Float8GetDatum'
postgis_proj.o(.text+0xc7c): In function `distance_ellipsoid':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_proj.c:344: undefined
postgis_proj.o(.text+0xc89):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:345: undefined reference to `_pg_detoast_datum'
postgis_proj.o(.text+0xca7):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:355: undefined reference to `_elog'
postgis_proj.o(.text+0xd4d):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_proj.c:379: undefined reference to `_Float8GetDatum'
postgis_chip.o(.text+0x207): In function `CHIP_in':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:40: undefined
postgis_chip.o(.text+0x254):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:46: undefined reference to `_elog'
postgis_chip.o(.text+0x27b):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:50: undefined reference to `__imp__CurrentMemoryContext'
postgis_chip.o(.text+0x28b):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:50: undefined reference to `_MemoryContextAlloc'
postgis_chip.o(.text+0x455): In function `CHIP_out':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:122: undefined
postgis_chip.o(.text+0x45e):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:130: undefined reference to `__imp__CurrentMemoryContext'
postgis_chip.o(.text+0x470):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:130: undefined reference to `_MemoryContextAlloc'
postgis_chip.o(.text+0x4eb): In function `CHIP_to_geom':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:145: undefined
postgis_chip.o(.text+0x6c0): In function `srid_chip':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:175: undefined
postgis_chip.o(.text+0x6f0): In function `factor_chip':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:183: undefined
postgis_chip.o(.text+0x730): In function `datatype_chip':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:192: undefined
postgis_chip.o(.text+0x760): In function `compression_chip':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:200: undefined
postgis_chip.o(.text+0x790):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:209: more undefined references to `_pg_detoast_datum' follow
postgis_chip.o(.text+0x7fd): In function `setsrid_chip':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:231: undefined
postgis_chip.o(.text+0x810):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:231: undefined reference to `_MemoryContextAlloc'
postgis_chip.o(.text+0x883): In function `setfactor_chip':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:242: undefined
postgis_chip.o(.text+0x88f):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:246: undefined reference to `__imp__CurrentMemoryContext'
postgis_chip.o(.text+0x8a2):/usr/share/postgresql/contrib/postgis-0.7.4/post
gis_chip.c:246: undefined reference to `_MemoryContextAlloc'
postgis_chip.o(.text+0x6fe): In function `factor_chip':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_chip.c:185: undefined
reference to `_Float4GetDatum'
postgis_transform.o(.text+0xb6): In function `transform_geom':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_transform.c:428:
postgis_gist_72.o(.text+0xa): In function `convert_box3d_to_box':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:68: undefined
postgis_gist_72.o(.text+0x1f):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_gist_72.c:68: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0xa1): In function `ggeometry_compress':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:87: undefined
postgis_gist_72.o(.text+0xb3):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_gist_72.c:87: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0xea):/usr/share/postgresql/contrib/postgis-0.7.4/po
stgis_gist_72.c:98: undefined reference to `_pg_detoast_datum'
postgis_gist_72.o(.text+0x106):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:102: undefined reference to `_pfree'
postgis_gist_72.o(.text+0x15c): In function `ggeometry_consistent':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:122: undefined
postgis_gist_72.o(.text+0x19f):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:143: undefined reference to `_pfree'
postgis_gist_72.o(.text+0x213): In function `rtree_internal_consistent':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:161: undefined
reference to `_box_overleft'
postgis_gist_72.o(.text+0x220):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:161: undefined reference to `_DirectFunctionCall2'
postgis_gist_72.o(.text+0x237):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:168: undefined reference to `_box_right'
postgis_gist_72.o(.text+0x240):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:172: undefined reference to `_box_contain'
postgis_gist_72.o(.text+0x253):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:175: undefined reference to `_box_overlap'
postgis_gist_72.o(.text+0x2b4): In function `gbox_union':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:209: undefined
postgis_gist_72.o(.text+0x2cb):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:209: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x3ee): In function `gbox_penalty':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:248: undefined
reference to `_rt_box_union'
postgis_gist_72.o(.text+0x3ff):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:248: undefined reference to `_DirectFunctionCall2'
postgis_gist_72.o(.text+0x444):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:251: undefined reference to `_pfree'
postgis_gist_72.o(.text+0x5fc): In function `gbox_picksplit':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:338: undefined
postgis_gist_72.o(.text+0x611):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:338: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x619):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:339: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x627):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:339: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x62f):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:340: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x641):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:340: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x649):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:341: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x65b):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:341: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x791):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:373: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x79f):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:373: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x7a7):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:374: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x7b5):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:374: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x7bd):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:375: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x7cf):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:375: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x7d6):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:376: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x7e8):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:376: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0x951):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:406: undefined reference to `__imp__CurrentMemoryContext'
postgis_gist_72.o(.text+0x965):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:406: undefined reference to `_MemoryContextAlloc'
postgis_gist_72.o(.text+0xb82):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:435: undefined reference to `_pfree'
postgis_gist_72.o(.text+0xbd2):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:479: undefined reference to `_pfree'
postgis_gist_72.o(.text+0xbdd):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:480: undefined reference to `_pfree'
postgis_gist_72.o(.text+0xbe8):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:481: undefined reference to `_pfree'
postgis_gist_72.o(.text+0xbf3):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:482: undefined reference to `_pfree'
postgis_gist_72.o(.text+0xc2c):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:465: more undefined references to `_pfree' follow
postgis_gist_72.o(.text+0xc88): In function `gbox_picksplit':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:445: undefined
reference to `_rt_box_inter'
postgis_gist_72.o(.text+0xc9b):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:445: undefined reference to `_DirectFunctionCall2'
postgis_gist_72.o(.text+0xca7):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:448: undefined reference to `_rt_box_inter'
postgis_gist_72.o(.text+0xcb4):/usr/share/postgresql/contrib/postgis-0.7.4/p
ostgis_gist_72.c:448: undefined reference to `_DirectFunctionCall2'
postgis_gist_72.o(.text+0x1340): In function `gbox_same':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:511: undefined
reference to `_box_same'
postgis_gist_72.o(.text+0x134d):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_gist_72.c:511: undefined reference to `_DirectFunctionCall2'
postgis_gist_72.o(.text+0x13aa): In function `size_box':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_gist_72.c:530: undefined
reference to `_rt_box_size'
postgis_gist_72.o(.text+0x13b3):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_gist_72.c:530: undefined reference to `_DirectFunctionCall2'
postgis_estimate.o(.text+0x33): In function `estimate_histogram2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_estimate.c:90: undefined
postgis_estimate.o(.text+0x358):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:183: undefined reference to `_Float8GetDatum'
postgis_estimate.o(.text+0x61a): In function `explode_histogram2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_estimate.c:194:
postgis_estimate.o(.text+0x63d):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:208: undefined reference to `_textout'
postgis_estimate.o(.text+0x651):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:208: undefined reference to `_DirectFunctionCall1'
postgis_estimate.o(.text+0x685):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:219: undefined reference to `_SPI_connect'
postgis_estimate.o(.text+0x69c):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:222: undefined reference to `_elog'
postgis_estimate.o(.text+0x6e6):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:229: undefined reference to `_SPI_exec'
postgis_estimate.o(.text+0x87d):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:252: undefined reference to `_SPI_exec'
postgis_estimate.o(.text+0x8b2):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:261: undefined reference to `_SPI_finish'
postgis_estimate.o(.text+0x8e6):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:255: undefined reference to `_elog'
postgis_estimate.o(.text+0x9d6): In function `build_histogram2d':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_estimate.c:278:
postgis_estimate.o(.text+0xab9):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:334: undefined reference to `_textout'
postgis_estimate.o(.text+0xacb):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:334: undefined reference to `_DirectFunctionCall1'
postgis_estimate.o(.text+0xad7):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:337: undefined reference to `_textout'
postgis_estimate.o(.text+0xae3):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:337: undefined reference to `_DirectFunctionCall1'
postgis_estimate.o(.text+0xaea):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:344: undefined reference to `_SPI_connect'
postgis_estimate.o(.text+0xb01):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:348: undefined reference to `_elog'
postgis_estimate.o(.text+0xb4b):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:357: undefined reference to `_SPI_prepare'
postgis_estimate.o(.text+0xb73):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:364: undefined reference to `_SPI_cursor_open'
postgis_estimate.o(.text+0xba6):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:376: undefined reference to `_SPI_cursor_fetch'
postgis_estimate.o(.text+0xbab):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:378: undefined reference to `__imp__SPI_processed'
postgis_estimate.o(.text+0xbc8):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:383: undefined reference to `__imp__SPI_tuptable'
postgis_estimate.o(.text+0xc72):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:391: undefined reference to `_SPI_getbinval'
postgis_estimate.o(.text+0xfb8):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:463: undefined reference to `_SPI_freetuptable'
postgis_estimate.o(.text+0xfd3):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:473: undefined reference to `_SPI_cursor_close'
postgis_estimate.o(.text+0xfd8):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:475: undefined reference to `_SPI_finish'
postgis_estimate.o(.text+0xff1):/usr/share/postgresql/contrib/postgis-0.7.4/
postgis_estimate.c:478: undefined reference to `_elog'
postgis_estimate.o(.text+0x1148):/usr/share/postgresql/contrib/postgis-0.7.4
/postgis_estimate.c:367: undefined reference to `_elog'
postgis_estimate.o(.text+0x118c): In function `get_restriction_var':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_estimate.c:534:
undefined reference to `_length'
postgis_estimate.o(.text+0x1249): In function `postgis_gist_sel':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_estimate.c:604:
postgis_estimate.o(.text+0x1294): In function `genericcostestimate2':
/usr/share/postgresql/contrib/postgis-0.7.4/postgis_estimate.c:751:
undefined reference to `_clauselist_selectivity'
postgis_estimate.o(.text+0x12f4):/usr/share/postgresql/contrib/postgis-0.7.4
/postgis_estimate.c:809: undefined reference to `_cost_qual_eval'
postgis_estimate.o(.text+0x12fd):/usr/share/postgresql/contrib/postgis-0.7.4
/postgis_estimate.c:809: undefined reference to `_cpu_index_tuple_cost'
postgis_estimate.o(.text+0x1374):/usr/share/postgresql/contrib/postgis-0.7.4
/postgis_estimate.c:743: undefined reference to `_listCopy'
postgis_estimate.o(.text+0x1380):/usr/share/postgresql/contrib/postgis-0.7.4
/postgis_estimate.c:743: undefined reference to `_nconc'
postgis_estimate.o(.text+0x1388):/usr/share/postgresql/contrib/postgis-0.7.4
/postgis_estimate.c:743: undefined reference to `_make_ands_explicit'
postgis_estimate.o(.text+0x1398):/usr/share/postgresql/contrib/postgis-0.7.4
/postgis_estimate.c:745: undefined reference to `_canonicalize_qual'
collect2: ld returned 1 exit status
dllwrap: gcc exited with status 1
make: *** [libpostgis.a] Error 1
> christian strobl
> diplom-geologe
> bayerisches geologisches landesamt
> heßstraße 128
> d-80797 münchen
> telefon: (089) 9214-2774
> christian.strobl at gla.bayern.de
> http://www.bayern.de/gla
