[postgis-users] compiling postgis with postgres 7.3 and cygwin
Norman Vine
nhv at cape.com
Fri Jan 10 07:05:09 PST 2003
It seems as if the Makefile attached to the original message was scrubbed
---------------------- multipart/mixed attachment
Type: application/octet-stream
Desc: not available
so for the archives I have included it inline below
Norman
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Wednesday, January 01, 2003 11:17 AM
Subject: Re: [postgis-users] compiling postgis with postgres 7.3 and cygwin
> Klaus Benndorf writes:
> > I tried to install postgis under Windows XP, following the "NON-UNIX
> > User's Guide". Everything worked fine and I had no problems with
> > configure and make of Postgres. But now make of postgis shows a lot of
> > undefined references. In the mailing list I found the hint, that
> > libpostgres.a might be not found, but it exists and I copied it to
> > different directories, that are definded in Makefile.
> > Any idea what to do?
> For some reason the PostGIS Makefile is not adding -lpostgres to
> the dllwrap command :-(
> The attached Makefile works for me
> also see
> http://postgis.refractions.net/pipermail/postgis-users/2002-November/001793.html
> for a required change to the postgresql source
> < although this mentions the 7.2.3 tree this still applies to the 7.3.x tree >
> HTH
> Norman
====== cut here ======
# Configuration Directives
# Set USE_PROJ to 1 for Proj4 reprojection support
USE_PROJ=1
#PROJ_DIR=/usr/local
# Set USE_STATS to 1 for new GiST statistics collection support
# Note that this support requires additional columns in
# GEOMETRY_COLUMNS, so see the list archives for info or
# install a fresh database using postgis.sql
USE_STATS=1
subdir=contrib/postgis
# Default the root of the PostgreSQL source tree
# To use a non-standard location set the PGSQL_SRC environment
# variable to the appropriate location.
ifeq (${PGSQL_SRC},)
top_builddir = ../..
include $(top_builddir)/src/Makefile.global
LPATH := $$libdir
else
top_builddir = ${PGSQL_SRC}
LPATH := ${PWD}
endif
# Test the version string and set the USE_VERSION macro
# appropriately.
ifneq ($(findstring 7.1,$(VERSION)),)
USE_VERSION=71
else
ifneq ($(findstring 7.2,$(VERSION)),)
USE_VERSION=72
else
USE_VERSION=73
endif
endif
# Regression test temporary database.
TEST_DB=geom_regress
# Shared library parameters.
NAME=postgis
SO_MAJOR_VERSION=0
SO_MINOR_VERSION=7
# override CPPFLAGS := -I$(srcdir) $(CPPFLAGS)
# Altered for Cynwin
ifeq ($(USE_PROJ),1)
override CPPFLAGS := -g -I$(PROJ_DIR)/include -I$(srcdir)
$(CPPFLAGS) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"' -DUSE_PROJ -DUSE_VERSION=$(USE_VERSION)
else
override CPPFLAGS := -g -I$(srcdir) $(CPPFLAGS) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"' -DUSE_VERSION=$(USE_VERSION)
endif
override DLLLIBS := $(BE_DLLLIBS) $(DLLLIBS)
# Select proper GiST support C file
ifeq ($(USE_VERSION),71)
GIST_SUPPORT=71
else
GIST_SUPPORT=72
endif
OBJS=postgis_debug.o postgis_ops.o postgis_fn.o postgis_inout.o postgis_proj.o postgis_chip.o postgis_transform.o
postgis_gist_$(GIST_SUPPORT).o postgis_estimate.o
# Add libraries that libpq depends (or might depend) on into the
# shared library link. (The order in which you list them here doesn't
# matter.)
SHLIB_LINK := $(LDFLAGS) ../../src/backend/libpostgres.a -lproj
# Makefile targets
all: all-lib $(NAME).sql $(NAME).sql $(NAME)_undef.sql loaderdumper
loaderdumper:
$(MAKE) -C loader
# Shared library stuff
include $(top_srcdir)/src/Makefile.shlib
$(NAME).sql: $(NAME)_sql_common.sql.in $(NAME)_sql_$(USE_VERSION)_end.sql.in $(NAME)_sql_$(USE_VERSION)_start.sql.in
cat $(NAME)_sql_$(USE_VERSION)_start.sql.in $(NAME)_sql_common.sql.in $(NAME)_sql_$(USE_VERSION)_end.sql.in | sed -e
's:@MODULE_FILENAME@:$(LPATH)/$(shlib):g;s:@POSTGIS_VERSION@:$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION):g' > $@
$(NAME)_undef.sql: $(NAME).sql create_undef.pl
perl create_undef.pl $< $(USE_VERSION) > $@
install: all installdirs install-lib
$(INSTALL_DATA) $(srcdir)/README.$(NAME) $(docdir)/contrib
$(INSTALL_DATA) $(NAME).sql $(datadir)/contrib
$(INSTALL_DATA) $(NAME)_undef.sql $(datadir)/contrib
$(INSTALL_DATA) spatial_ref_sys.sql $(datadir)/contrib
$(INSTALL_DATA) README.postgis $(datadir)/contrib
$(MAKE) -C loader install
installdirs:
$(mkinstalldirs) $(docdir)/contrib $(datadir)/contrib $(libdir)
uninstall: uninstall-lib
@rm -f $(docdir)/contrib/README.$(NAME) $(datadir)/contrib/$(NAME).sql
clean distclean maintainer-clean: clean-lib
@rm -f $(OBJS) $(NAME).sql $(NAME)_undef.sql
$(MAKE) -C loader clean
test: all
csh regress/regress.csh $(TEST_DB)
