[postgis-users] compiling postgis with postgres 7.3 and cygwin
Norman Vine
nhv at cape.com
Mon Jan 6 12:04:26 PST 2003
Klaus Benndorf writes:
> I tried to run your Makefile, but without the patches I still have the same
> problems.
> Do you know where to find them? They are not attached in
> http://postgis.refractions.net/pipermail/postgis-users/2002-November/001793.
> html
The required change is in the message
> > I believe that adding a DLLIMPORT to src/include/optimizer/cost.h:
> > extern DLLIMPORT double cpu_index_tuple_cost;
> > should fix this one.
> **BINGO **
> With this change the DLL compiles and works !
HTH
Norman
