[postgis-users] Center of a path.
Luís Mota luis.mota at iscte.pt
Sat Jan 11 14:07:04 PST 2003
Hi.
I had a similar need and developed a small plpgsql to compute the center of
a linestring. If you need this, I can send the code.
Best regards, Luís Mota
----- Original Message -----
> The problem is that this "centre" is not necessary on the path. I would
> like to know if a function exist and can find the centre of a path with
> this definition : "A point ON the path, which is half way from each end
> of the path".
