[postgis-users] shp2pgsql and schemas
Carl Anderson
carl.anderson at vadose.org
Fri Jul 4 10:52:51 PDT 2003
On 2003.07.04 11:55 Paul Ramsey wrote:
> Now that schemas actually *exist* in pgsql, our behavior is in wrong.
> The schema idea can be literally and correctly translated into pgsql
> terms. So AddGeometryColumn should be dumbed down to just
> AddGeometryColumn( <tablename>, <columnname>, <srid>, <type>, <dim> )
There would need to be a period of transition so that client apps can
work with the old (current) or newer (schema sensitive) style.
So if an app (such as qgis) uses the geometry_columns table as a catalog
of available geometry tables, it should try to look for whatever it
finds in the f_table_schema and f_table_name fields ( select * from
schema.table)
and if that fails and IF the f_table_schema is the same as the
connected database name (detected not from f_table_catalog)
then a second attempt is made dropping the schema portion.
in such a way users with the current geometry_columns can be supported
as well as support a newer style.
If I may be so bold,
a document clearly explaining that the geometry_colums table is a
catalog of postgis enabled tables, and developers should be encouraged
to honor f_table_catalog, f_table_schema, f_table_name and
f_geometry_column when looking for things they find in the catalog.
On the other hand applications such as UMN mapserver or OGR/GDAL
which do not use the catalog, would be aware that geometries in tables
can occur in all the ways the catalog can identify. UMN mapserver
depends on srid(schema,table,columnname) to find some table info.
While i do not profess to see into the future it seems likely that
PostgreSQL will one day allow cross database queries (select * from
db.schema.table). As such f_table_catalog should be treated as
meaningful
and interpreted as
blank string use current database connection
(no other possible value)
any other value don't use until Postgis supports cross database
queries
if a seperate database connection would be required to access something
in the catalog (geometry_columns) then it is not put into the catalog.
when PostgreSQL allows access to other databases using the current
connection then and only then should f_table_catalog be populated.
C.
