[postgis-users] shp2pgsql and schemas
Carl Anderson
carl.anderson at vadose.org
Fri Jul 4 17:57:23 PDT 2003
On 2003.07.04 14:06 Paul Ramsey wrote:
> Carl Anderson wrote:
>> There would need to be a period of transition so that client apps
>> can work with the old (current) or newer (schema sensitive) style.
> Isn't it likely that client apps currently ignore the 'schema'
> column, since it is patently useless?
Well as soon a shp2pgsql gets changed something like qgis will have to
support users in the old (current) style and users in the new style.
as soon as non bogus data is in f_table_schema apps will have to
know how to differentiate the old bogus info from the new non bogus
info. or have a strategy to deal with both.
the method to try with f_table_schema as meaningful and failover to try
as bogus (if f_table_schema == the database name) seems to be a
fairly easy way to deal with the issue.
C.
