[postgis-users] Insert data larger than 1 Gig...
David Blasby dblasby at refractions.net
Mon Jul 7 11:57:46 PDT 2003
Is the resulting data (in binary form) > 1GB?  If so, you might have
problems - postgresql has either a 1GB or 2GB size limit for a single
chunk of data.
If the binary is < 1GB, then you could try using Base-64 encoding
instead of hex - it would be a bit more efficient.  You'll have to
change the postgis_chip.c "chip_in()" and "chip_out()" functions.
Third, you could load the data in chunks - this would involve writing a
mergeChip(CHIP,CHIP) function in postgis_chip.c, and a split chip
function in your client.
insert into datatable values (<a chip 1 >);
update datatable set mychip = mergeChip(mychip, <a chip 2>);
update datatable set mychip = mergeChip(mychip, <a chip 3>);
update datatable set mychip = mergeChip(mychip, <a chip 4>);
But, the real question is why do you want to put something that big in
the database?   Wouldnt it make more sense to cut it up into smaller chunks?
dave
