[postgis-users] pgsql2shp
Elstermann, Mike
Mike.Elstermann at itc-halle.de
Tue Jul 8 02:35:14 PDT 2003
if have an tcp/ip-problem
postgres at susi:/usr/local/pgsql/bin> pgsql2shp gisdb alk_fo
Connection to database 'gisdb' failed.
could not connect to server: Connection refused
Is the server running on host localhost and accepting
TCP/IP connections on port 5432?
how can i start postmaster with i-option
---- output for help --------------
postgres at susi:/usr/local/pgsql/bin> pg_ctl --help
pg_ctl is a utility to start, stop, restart, reload configuration
files,
or report the status of a PostgreSQL server.
Usage:
pg_ctl start [-w] [-D DATADIR] [-s] [-l FILENAME] [-o "OPTIONS"]
pg_ctl stop [-W] [-D DATADIR] [-s] [-m SHUTDOWN-MODE]
pg_ctl restart [-w] [-D DATADIR] [-s] [-m SHUTDOWN-MODE] [-o
"OPTIONS"]
pg_ctl reload [-D DATADIR] [-s]
pg_ctl status [-D DATADIR]
Common options:
-D DATADIR location of the database storage area
-s only print errors, no informational messages
-w wait until operation completes
-W do not wait until operation completes
--help show this help, then exit
--version output version information, then exit
(The default is to wait for shutdown, but not for start or restart.)
If the -D option is omitted, the environment variable PGDATA is
used.
Options for start or restart:
-l FILENAME write (or append) server log to FILENAME.
The
use of this option is highly recommended.
-o OPTIONS command line options to pass to the
postmaster
(PostgreSQL server executable)
-p PATH-TO-POSTMASTER normally not necessary
Options for stop or restart:
-m SHUTDOWN-MODE may be 'smart', 'fast', or 'immediate'
Shutdown modes are:
smart quit after all clients have disconnected
fast quit directly, with proper shutdown
immediate quit without complete shutdown; will lead to recovery
on restart
Report bugs to <pgsql-bugs at postgresql.org>.
an which values must i insert in the "pg_hba.conf" and the "postmaster.conf"
::: mfg. Mike Elstermann [mikeE.], Teamleiter GIS/RIS, e-Solutions
::: IT-Consult Halle GmbH, Bornknechtstraße 5, 06108 Halle (Saale)
::: Sitz: Rathausstraße 3
::: Tel.: +49 345 221 4237, Fax: +49 345 221 4236, mobil: +49 160 71 545 02
::: mike.elstermann at itc-halle.de ::: http://www.itc-halle.de
::: GeoDaten Online? -> http://www.itcgis.de
