[postgis-users] cannt connect in mapserver
Chen Fu
novalet at yahoo.com.cn
Thu Jul 10 06:28:23 PDT 2003
Hi!
I recently try to build a postgis on my redhat8 box as
a dynamic data source for mapserver webgis.
I can use psql to add some geometry into the table.
for example
chenfu=# select * from test;
id | name | geom
1 | geom 1 | SRID=-1;POINT(1 1)
2 | geom 2 | SRID=-1;LINESTRING(1 2,2 3)
3 | geom 3 | SRID=-1;POLYGON((2 1,3 1,3 3,2 1))
But when i try to connect this table with a mapserver
map file. It doesn't work.
MAP
NAME APPLE
STATUS ON
EXTENT -10 -10 10 10
UNITS METERS
SIZE 100 100
IMAGETYPE PNG
LAYER
CONNECTIONTYPE postgis
NAME "test"
CONNECTION "user=postgres password=postgres
dbname=chenfu host=localhost"
DATA "geom FROM test"
STATUS ON
TYPE LINE
END
END # Map File
Test this map file with shp2img, the output info is
[root at cbers mapserver-4.0b]# ./shp2img -m my.map -o
msDrawMap(): Image handling error. Failed to draw
layer named 'test'.
Do you know what's wrong? How can i confirm my postgis
is correctly configured. Or is there any other way
besides mapserver to test the connection string is
correct?
I am blocked in this problem for almost one week long.
Thank you for any suggestion!
Remote Scensing Satellite Ground Station
Chinese Academy of Science
_________________________________________________________
Do You Yahoo!?
国内电邮用户反垃圾调查拉开帷幕
http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.tech.yahoo.com/zhuanti/laji/index.html
