[postgis-users] MapServer PostgreSQL and persistent databaseconnections
Jan Hartmann jhart at frw.uva.nl
Fri Jul 11 02:58:17 PDT 2003
Paul, do you know WHY Oracle / SDE have such long connection times,
compared to PostgreSQL? Is there some added functionality/bookkeeping
invoved?
Jan
Paul Ramsey wrote:
>   The eternal question, to connection pool or not to connection pool. :)
> The reason why connection pooling is considered an important problem for
> enterprise application developers is... because Oracle is really slow at
> establishing a connection. Really, that is why! PostgreSQL connections times
> are inconsequential. In the context of a process as computationally intensive
> as Mapserver, PgSQL connections times might as well be considered to be zero.
>   This gets discussed every month or so on the Mapserver list, and the bottom
> line is that 99% of your processing time for a given map creation will be
> spent retrieving and rendering the data. Connection time for PostgreSQL is
> completely ignorable in term of impact on system load.
>   For Oracle and ArcSDE, connection time is non-trivial, and that is a
> problem.
>   Because there are some connection time issues with some of the backends, for
> Mapserver 4.0 there has been an enhancement to ensure that database
> connections are pooled PER MAPPING INVOCATION. So within a particular
> instantiation of the mapserv CGI, only one connection to each database is
> used. So if I have 15 ArcSDE layers in my map, I will only connect ONCE, not
> 15 times.
>   The infrastructure of inter-layer connection pooling exists in Mapserver
> 4.0, and has been implemented on ArcSDE connections only, so far, but is
> completely reusable for OracleSpatial and PgSQL layers. The implementation for
> those layers just needs to be done.
> Yours,
> Paul
> Quoting Hubert Fröhlich <hubert.froehlich at bvv.bayern.de>:
>>Hi lists,
>>I use UMN MapServer with PostGIS.
>>When programming web applications with, say, PHP, Apache and PostgreSQL,
>>I can speed up database performance by keeping database connections
>>persistent and, therefore avoiding overhead by login and
>>authentification procedures.
>>When using MapServer with PostGIS in a CGI-style way like in the
>>documetnation examples, I guess that I have to open and reopen the
>>PostGIS connection every time I start a mapserv process (at least I
>>haven't found a different way) because the database connection is
>>defined in the mapfile.
>>Now my question: Is it possible that MapServer can control database
>>connections  and keep them persistent?
>>Or may be this an issue for the development team?
>>Any hints will be greatly appreciated.
>>Greetings,
>>Hubert
>>Dr.-Ing. Hubert Fröhlich
>>Bezirksfinanzdirektion München
>>Alexandrastr. 3, D-80538 München, GERMANY
>>Tel. :+49 (0)89 / 2190 - 2980
>>Fax  :+49 (0)89 / 2190 - 2459
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
