[postgis-users] MapServer PostgreSQL and persistent	databaseconnections
    Paul Ramsey
    pramsey at refractions.net
    Thu Jul 10 10:14:27 PDT 2003
  The eternal question, to connection pool or not to connection pool. :)
The reason why connection pooling is considered an important problem for
enterprise application developers is... because Oracle is really slow at
establishing a connection. Really, that is why! PostgreSQL connections times
are inconsequential. In the context of a process as computationally intensive
as Mapserver, PgSQL connections times might as well be considered to be zero.
  This gets discussed every month or so on the Mapserver list, and the bottom
line is that 99% of your processing time for a given map creation will be
spent retrieving and rendering the data. Connection time for PostgreSQL is
completely ignorable in term of impact on system load.
  For Oracle and ArcSDE, connection time is non-trivial, and that is a
problem.
  Because there are some connection time issues with some of the backends, for
Mapserver 4.0 there has been an enhancement to ensure that database
connections are pooled PER MAPPING INVOCATION. So within a particular
instantiation of the mapserv CGI, only one connection to each database is
used. So if I have 15 ArcSDE layers in my map, I will only connect ONCE, not
15 times.
  The infrastructure of inter-layer connection pooling exists in Mapserver
4.0, and has been implemented on ArcSDE connections only, so far, but is
completely reusable for OracleSpatial and PgSQL layers. The implementation for
those layers just needs to be done.
Yours,
Paul
Quoting Hubert Fröhlich <hubert.froehlich at bvv.bayern.de>:
> Hi lists,
> I use UMN MapServer with PostGIS.
> When programming web applications with, say, PHP, Apache and PostgreSQL,
> I can speed up database performance by keeping database connections
> persistent and, therefore avoiding overhead by login and
> authentification procedures.
> When using MapServer with PostGIS in a CGI-style way like in the
> documetnation examples, I guess that I have to open and reopen the
> PostGIS connection every time I start a mapserv process (at least I
> haven't found a different way) because the database connection is
> defined in the mapfile.
> Now my question: Is it possible that MapServer can control database
> connections  and keep them persistent?
> Or may be this an issue for the development team?
> Any hints will be greatly appreciated.
> Greetings,
> Hubert
> Dr.-Ing. Hubert Fröhlich
> Bezirksfinanzdirektion München
> Alexandrastr. 3, D-80538 München, GERMANY
> Tel. :+49 (0)89 / 2190 - 2980
> Fax  :+49 (0)89 / 2190 - 2459
> postgis-users mailing list
