[postgis-users] Windows application communicating with PostGI S?
Obe, Regina DND\MIS
robe.dnd at ci.boston.ma.us
Thu Jul 24 05:51:53 PDT 2003
If you have apps written in VB.NET/C# etc. you may want to look at the
Postgres.NET driver. I think its part of the Mono Project.
I'm not sure how robust it is right now since it is still in beta, but I am
using it for some simple ASP.NET apps and the performance has been adequate
for those. I imagine that eventually the performance will be better than
the ODBC driver - if it isn't already. Also the code is opensource so
someone could conceivably extend it to support PostGIS spatial components
similar to what has been done with the JDBC driver.
http://gborg.postgresql.org/project/npgsql/projdisplay.php
-----Original Message-----
From: Christina Biakowski (CCGIS) [mailto:christina.biakowski at ccgis.de]
Sent: Thursday, July 24, 2003 5:31 AM
To: PostGIS Users Discussion
Subject: AW: [postgis-users] Windows application communicating with PostGIS?
Hello Jaromir,
see
http://gborg.postgresql.org/project/psqlodbc/projdisplay.php
for a postgresql odbc-driver.
Having configured an odbc-connection for your postgis-database you can e.g.
load your postgis-tables into an access-database. With VB-applications via
the odbc-connection you can easily read/write postgis data from windows
using the adodb-library.
I hope this helps,
regards,
Christina
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]Im Auftrag von Jaromir
Svasta
Gesendet: Donnerstag, 24. Juli 2003 10:01
An: PostGIS Users Discussion
Betreff: [postgis-users] Windows application communicating with PostGIS?
Hello,
How can strings be sent to (and retrieved from) PostGIS, which runs on a
Linux server, from a Windows application? Both Linux and Windows computers
are networked. Using ODBC driver? Then how?
I am new to PostGIS.
Any suggestion is greatly appreciated!
Jaromir Svasta
Geological Survey of Slovakia
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
