[postgis-users] Re: Error messages in PostGIS (change SRID and change projections)
chodgson at refractions.net chodgson at refractions.net
Mon Jun 2 10:07:29 PDT 2003
>From the postgis manual:
transform(geometry,integer)
Returns a new geometry with its coordinates transformed to the SRID referenced
by the integer parameter. The source and destination SRIDs must exist in the
SPATIAL_REF_SYS table.
Create a new geometry table, and fill it with stuff selected from your original
table and transformed to the new SRID - the trickiest part is determining the
SRIDs - and making sure they are in the spatial_ref_sys table. Look at
spatial_ref_sys.sql provided in the postgis distribution.
Chris
Quoting Rosangela Silva <rosangela.silva at zenitpolar.com.br>:
> Hi all,
> Sorry for only now I'm answering about my test to change SRID parameter.
> I used the following commands, like you recommended and
> it works well, thanks Chris, Tyler and strk (?) for helps!!
> Only a question is how can I see the SRID for one element, to check it??
> ALTER TABLE mytable DROP CONSTRAINT "$1" RESTRICT;
> UPDATE mytable SET the_geom = SETSRID (the_geom, 4326);
> ALTER TABLE mytable ADD CONSTRAINT "$1" CHECK (SRID(the_geom)=4326);
> By the way, do you know how to change the projections of a table?
> For example convert coords of Datum SAD69 (SRID=?) to Datum WGS84
> (SRID=4326) ??
> Thanks in advance,
> Rosângela.
> >Tyler, the problem with your suggestion is that there is a constraint on
> any
> >table created using "AddGeometryColumn()" which requires all the
> >geometries in
> >the column to have the srid specified in the the call to AddGeometryColumn.
> >You
> >will probably need to drop this constraint using the DROP CONSTRAINT sql
> >command, then do the update (as explained by Tyler), then add the
> constraint
> >back, and then update the geometry_columns table to have the correct srid
> in >it
> >for that column.
> >An alternative would be to add another geometry column to the same table,
> >with
> >the correct srid, and then set the value of the new geometry column equal
> to
> >the old geometry column with the srid set, for example:
> >UPDATE foo SET new_geom = setSRID( old_geom, 4326 );
> >Then delete the old geometry column using "DropGeometryColumn()".
> >HTH.
> >Chris
> >Quoting Tyler Mitchell <TMitchell at lignum.com>:
> > Use the function:
> > SetSRID(geometry) to update the geometry in your table, i.e.
> > UPDATE mytable
> > SET the_geom = SetSRID(the_geom)=4326
> > I've never done it, anyone see problems with it?
> > Tyler
> >                       strk <strk at freek.keybit.net>
> >                       Sent by:                                  To:
> > PostGIS Users Discussion
> >                       postgis-users-bounces at postgis.refr
> > <postgis-users at postgis.refractions.net>
> >                       actions.net                               cc:
> >        Fax to:
> >        Subject:
> Re:
> >                       05/23/2003 02:14 AM                        PostGIS
> >                       Please respond to PostGIS Users
> >                       Discussion
> > rosangela.silva wrote:
> > > Hi,
> > > Thanks for information. Is everything ok now.
> > > But, if I've already created a spatial table with SRID = -1
> > > how can I convert this table (and all its elements) for SRID=4326?
> > > Is it possible??
> > Ok, this  sounds like something that needs a better user interface to
> > be done cleanly... AFAIK you have to hack it.
> > I'd try to update the geometry_column first (setting the SRID to the value
> > 4326) and then update the  your spatial table using the setSRID() function
> > on the geometry column.
> > If the constraints dinamically check SRID from geometry_columns
> > table that should work.
> > --strk;
> > > Thanks
> > > Rosângela
> > >   > Hello all,
> > >   > I'm having two problems with PostGIS that I don't know
> > >   > how to solve them. I don't have much experience with database
> > >   > management. Could you help me, please?
> > >   > I DROP a table continent, but I don't DROP the spatial
> > >   > index before, and when I try to execute the sql again
> > >   > I receive the message below:
> > >   > $ psql -d geobusca -f continent.sql
> > >   > ERROR:  Relation 'continent' already exists
> > >   > psql:continent.sql:1: ERROR:  Relation 'continent' already exists
> > >   > ERROR:  Cannot insert a duplicate key into unique index
> > geometry_columns_pk
> > >   > WARNING:  Error occurred while executing PL/pgSQL function
> > addgeometrycolumn
> > >   > WARNING:  line 39 at execute statement
> > >   > psql:continent.sql:2: WARNING:  line 39 at execute statementng
> > PL/pgSQL function
> > >   > psql:continent.sql:2: ERROR:  Cannot insert a duplicate key into
> > unique index ge
> > >   > ometry_columns_pk
> > >   You need to delete from geometry_columns where f_table_name
> > = 'continent'.
> > >   This is done automatically if you use dropGeometryColumn() befor
> > dropping
> > >   the table.
> > >   > In other case, I delete a record from a spatial table and when I try
> > to
> > >   > insert the same record again (with some changes) I received the
> > message
> > >   > below:
> > >   > gisdb=# INSERT INTO wpt (wpt_waypointID, wpt_Name, the_geom) VALUES
> > (9, 'TUN
> > >   > L25', GeometryFromText('POINT(-46.63758 -23.97345)', 4326));
> > >   > ERROR:  ExecInsert: rejected due to CHECK constraint "$1" on "wpt"
> > >   > gisdb=#
> > >   The CHECK constraint "$1" tries to force geometry SRID as specified in
> > >   the geometry_columns. You have removed the information related to
> > >   the specified table, thus the check is rejected.
> > >   > I'm using LATLONG/WGS84 and the wpt table is:
> > >   >                Table "public.wpt"
> > >   >      Column     |       Type        | Modifiers
> > >   >  wpt_waypointid | bigint            |
> > >   >  wpt_name        | character varying |
> > >   >  the_geom        | geometry          |
> > >   > Check constraints: "$1" (srid(the_geom) = -1)
> > >   >                    "$2" ((geometrytype(the_geom) = 'POINT'::text) OR
> > (the_geom IS NULL))
> > >   > But I used the sintaxe bellow to create the table:
> > >   > CREATE TABLE wpt (wpt_waypointID bigint, wpt_Name varchar);
> > >   > SELECT AddGeometryColumn('geobusca','wpt','the_geom',
> > 4326,'POINT',2);
> > >   > What can I have to do?
> > >   The creation sql seems good, but you  have to use DropGeometryColumn()
> > >   on the table before dropping the table itself.
> > >   If the problems also occurs immediatly after table creation (you never
> > >   tried to drop anything) try omitting the first parameter from
> > >   AddGeometryColumn.
> > >   --strk;
> > >   ----- Original Message -----
> > >   From: Rosangela Silva
> > >   To: postgis-users at postgis.refractions.net
> > >   Sent: Thursday, May 22, 2003 12:02 PM
> > >   Subject: Error messages in PostGIS
> > >   Hello all,
> > geometry_columns_pk
> > addgeometrycolumn
> PL/pgSQL
> > function
> unique
> > index ge
> > >   ometry_columns_pk
> to
> message
> > >   below:
> (9,
> > 'TUN
> > >   gisdb=#
> > >                  Table "public.wpt"
> > (the_geom IS NULL))
> > >   SELECT AddGeometryColumn('geobusca','wpt','the_geom', 4326,'POINT',2);
> > >   Thanks
> > >   Rosângela.
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
