[postgis-users] debug_level options?
Tyler Mitchell
TMitchell at lignum.com
Fri Jun 6 09:38:08 PDT 2003
Who knows if the debug options are even in the binary? Because the
compilation was done behind closed doors and I've seen some quirky things
every now and then, I wouldn't be surprised if they left it out.
Did anyone on this list help get the postgis compiled against Multeras
win32 version of postgres?
Tyler
"Mike Leahy"
<mgleahy at fes.uwaterloo.ca> To: "'PostGIS Users Discussion'"
Sent by: <postgis-users at postgis.refractions.net>
postgis-users-bounces at postgis.refr cc:
actions.net Fax to:
Subject: RE: [postgis-users] debug_level options?
06/05/2003 04:08 PM
Please respond to PostGIS Users
Discussion
Okay...checked that file, and the debug_level there is 0 (out of a range
of 0 to 16). I think there must be another debug_level option somewhere
else that I need to change...but I haven't found it in that folder...
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: June 5, 2003 6:06 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] debug_level options?
If I recall correctly, you are using a precompiled binary. Check in the
postgresql.conf file and see if the debugging is cranked up in there to
some non-default value.
P.
Mike Leahy wrote:
> Hello all again.
> I have what I hope is a fairly simple question.when I do a query on a
> map using layers from a PostGIS database, string of results will
scroll
> by in the Postmaster command window. Most of it looks like super long
> series of TARGETENTRY statements (below).
> This is also followed by a series of NOTICE messages before the query
> finishes. The whole thing overall is working fine, but it can
sometimes
> be a fairly lengthy wait if there are multiple layers and lots of
small
> polygons. I expect it would be significantly faster if I could have
the
> postmaster work in a quiet mode of some type, either with the window
> hidden or by turning off message reporting. I experimented with
passing
> a debug_level parameter (-d 1) with the pg_ctl command (i.e., pg_ctl
> start -o "-i -d 1"), but that didn't really change anything. Does
> anybody have any suggestions?
> BTW: We are volunteering for an NGO in Peru to build an education
> information system based on spatial data, and have relatively little
> access to any development support network. As a result, we have been
> relying heavily on email discussion lists. We appreciate all of the
> help that has been offered by the participants of this list.
> Kind regards,
> Mike
> __________________________________________
> { TARGETENTRY
> :resdom
> { RESDOM
> :resno 66
> :restype 23
> :restypmod -1
> :resname a_gra07gm
> :reskey 0
> :reskeyop 0
> :ressortgroupref 0
> :resjunk false
> :expr
> { VAR
> :varno 1
> :varattno 66
> :vartype 23
> :vartypmod -1
> :varlevelsup 0
> :varnoold 1
> :varoattno 66
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
