[postgis-users] debug_level options?
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Mon Jun 9 00:10:57 PDT 2003
Hi Mike,
In your postgresql.conf, make sure that all the options beginning
'debug_print_' are set to false and see if that solves your problem.
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Mike Leahy
> Sent: 06 June 2003 00:09
> To: 'PostGIS Users Discussion'
> Subject: RE: [postgis-users] debug_level options?
> Okay...checked that file, and the debug_level there is 0 (out
> of a range of 0 to 16). I think there must be another
> debug_level option somewhere else that I need to change...but
> I haven't found it in that folder...
