[postgis-users] stat failed on file '$libdir/postgis.dll': No such file or directory
Tyler Mitchell TMitchell at lignum.com
Fri Jun 13 08:50:25 PDT 2003
If you are using a package you grabbed for cygwin, you should probably be
using the postgis.sql that came with it.
I think mine was in /usr/src/postgresql/contrib/postgis/postgis.sql.
|         |           "Mike Leahy"                      |
|         |           <mgleahy at fes.uwaterloo.ca>        |
|         |           Sent by:                          |
|         |           postgis-users-bounces at postgis.refr|
|         |           actions.net                       |
|         |           06/13/2003 08:44 AM               |
|         |           Please respond to PostGIS Users   |
|         |           Discussion                        |
  |       To:       "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>                                         |
  |       cc:        |
  |       Fax to:        |
  |       Subject:  RE: [postgis-users] stat failed on file '$libdir/postgis.dll': No       such file or directory               |
Okay, replacing $libdir with the windows path worked.  Now I'm getting yet
another error near the end of the script:
psql:postgis.sql:816: ERROR:  OperatorDef: function
postgis_gist_sel(internal, oid, internal, integer) does not exist
Any suggestions for this one?  Perhaps this is because the postgis.sql I'm
using (the one that came with the version Tyler Mitchell made available to
me) doesn't correspond with the latest version of postgis?  If so, does
anybody have one that is current?
Mike
      -----Original Message-----
      From: postgis-users-bounces at postgis.refractions.net
      [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
      Obe, Regina DND\MIS
      Sent: June 13, 2003 10:33 AM
      To: 'PostGIS Users Discussion'
      Actually slight correction.  You have to use the unix path I think.
      /lib
      I think is what you want to replace it with if you have it in the lib
      folder.
            From: Mike Leahy [mailto:mgleahy at fes.uwaterloo.ca]
            Sent: Friday, June 13, 2003 11:26 AM
            To: postgis-users at postgis.refractions.net
            Subject: [postgis-users] stat failed on file
            Hello all,
            I've finally got the Cygwin version of PostgreSQL/PostGIS built
            ? yay!.  I used the DLLIMPORT command in cost.h, and ran "make
            clean" before trying the build a second time (this was the
            small detail I was unaware of all along).  Now I've got another
            error that occurs when I try to run the postgis.sql file after
            the createlang:
            psql:postgis.sql:249: ERROR: stat failed on file
            Yes, the DLL is in C:\cygwin\lib, but clearly there's something
            I'm missing.  I've got the PGLIB variable set in my environment
            settings (in WinXP)?but that doesn't seem to matter in this
            case?
            Any suggestions?
            Mike
