[postgis-users] stat failed on file '$libdir/postgis.dll': Nosuch file or directory
Mike Leahy
mgleahy at fes.uwaterloo.ca
Fri Jun 13 08:56:27 PDT 2003
Yes, found it, and it works (but only after I replace $libdir with
"C:/cygwin/lib"). Export libdir=/lib or even export
libdir=c:/cygwin/lib doesn't seem to work in my case...the parameter
shows up in the list when I type "env", but for some reason, that
doesn't do the trick.
Thanks for the help,
Mike
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Tyler Mitchell
Sent: June 13, 2003 10:50 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] stat failed on file '$libdir/postgis.dll':
If you are using a package you grabbed for cygwin, you should probably
be
using the postgis.sql that came with it.
I think mine was in /usr/src/postgresql/contrib/postgis/postgis.sql.
| | "Mike Leahy" |
| | <mgleahy at fes.uwaterloo.ca> |
| | Sent by: |
| | postgis-users-bounces at postgis.refr|
| | actions.net |
| | 06/13/2003 08:44 AM |
| | Please respond to PostGIS Users |
| | Discussion |
| To: "'PostGIS Users Discussion'"
<postgis-users at postgis.refractions.net>
| cc:
| Fax to:
'$libdir/postgis.dll': No such file or directory |
Okay, replacing $libdir with the windows path worked. Now I'm getting
yet
another error near the end of the script:
psql:postgis.sql:816: ERROR: OperatorDef: function
postgis_gist_sel(internal, oid, internal, integer) does not exist
Any suggestions for this one? Perhaps this is because the postgis.sql
I'm
using (the one that came with the version Tyler Mitchell made available
to
me) doesn't correspond with the latest version of postgis? If so, does
anybody have one that is current?
Mike
Of
Obe, Regina DND\MIS
Sent: June 13, 2003 10:33 AM
To: 'PostGIS Users Discussion'
Actually slight correction. You have to use the unix path I
think.
/lib
I think is what you want to replace it with if you have it in the
lib
folder.
From: Mike Leahy [mailto:mgleahy at fes.uwaterloo.ca]
Sent: Friday, June 13, 2003 11:26 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] stat failed on file
Hello all,
I've finally got the Cygwin version of PostgreSQL/PostGIS
built
? yay!. I used the DLLIMPORT command in cost.h, and ran
"make
clean" before trying the build a second time (this was the
small detail I was unaware of all along). Now I've got
another
error that occurs when I try to run the postgis.sql file
after
the createlang:
psql:postgis.sql:249: ERROR: stat failed on file
Yes, the DLL is in C:\cygwin\lib, but clearly there's
something
I'm missing. I've got the PGLIB variable set in my
environment
settings (in WinXP)?but that doesn't seem to matter in this
case?
Any suggestions?
Mike
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
