[postgis-users] Crash when creating GIST index
Benjamin Wragg
bwragg at tpg.com.au
Sun Mar 2 14:24:06 PST 2003
Hi all,
I'm have trouble when I create a GIST index on a geometry field in a
table. I get the following error:
create index featurethe_geom on feature using GIST(the_geom);
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: DEBUG: server
process
(pid 1430) was terminated by signal 11
DEBUG: terminating any other active server processes
DEBUG: all server processes terminated; reinitializing shared memory
and semaph
ores
DEBUG: database system was interrupted at 2003-03-03 08:33:07 CST
DEBUG: checkpoint record is at 0/63D9CE4
DEBUG: redo record is at 0/63D9CE4; undo record is at 0/0; shutdown
TRUE
DEBUG: next transaction id: 17744; next oid: 258077
DEBUG: database system was not properly shut down; automatic recovery
in progre
ss
FATAL 1: The database system is starting up
Failed.
!# DEBUG: redo starts at 0/63D9D24
DEBUG: ReadRecord: invalid magic number 0000 in log file 0, segment 6,
offset 4
104192
DEBUG: redo done at 0/63E60C0
DEBUG: database system is ready
I checked the list and read about a bug at
http://postgis.refractions.net/pipermail/postgis-users/2002-May/000978.h
tml in version 7.2.1 which sounds a little like the problem I'm having.
I'm running 7.2.2 on R.H 8, so does anyone know if this is fixed in this
release? If I run the same create index statement on a 7.2.3
winxp/cygwin install of postgres it works fine.
Cheers,
Benjamin Wragg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030303/de763211/attachment.html>
