[postgis-users] Crash when creating GIST index
Paul Ramsey
pramsey at refractions.net
Mon Mar 3 09:51:23 PST 2003
Well, firstly update to the best 7.2.X PgSQL you can get. Secondly,
update to the best PostGIS you can get. We did have some GiST crashes
with PostGIS early in the 7.2 series, but they were stomped out pretty
quickly.
Finally, if things still don't work, send us the data sample for testing.
P.
Benjamin Wragg wrote:
> Hi all,
> I'm have trouble when I create a GIST index on a geometry field in a
> table. I get the following error:
> create index featurethe_geom on feature using GIST(the_geom);
> server closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> The connection to the server was lost. Attempting reset: DEBUG: server
> process
> (pid 1430) was terminated by signal 11
> DEBUG: terminating any other active server processes
> DEBUG: all server processes terminated; reinitializing shared memory
> and semaph
> ores
> DEBUG: database system was interrupted at 2003-03-03 08:33:07 CST
> DEBUG: checkpoint record is at 0/63D9CE4
> DEBUG: redo record is at 0/63D9CE4; undo record is at 0/0; shutdown TRUE
> DEBUG: next transaction id: 17744; next oid: 258077
> DEBUG: database system was not properly shut down; automatic recovery
> in progre
> ss
> FATAL 1: The database system is starting up
> Failed.
> !# DEBUG: redo starts at 0/63D9D24
> DEBUG: ReadRecord: invalid magic number 0000 in log file 0, segment 6,
> offset 4
> 104192
> DEBUG: redo done at 0/63E60C0
> DEBUG: database system is ready
> I checked the list and read about a bug at
> http://postgis.refractions.net/pipermail/postgis-users/2002-May/000978.html in
> version 7.2.1 which sounds a little like the problem I'm having. I'm
> running 7.2.2 on R.H 8, so does anyone know if this is fixed in this
> release? If I run the same create index statement on a 7.2.3
> winxp/cygwin install of postgres it works fine.
> Cheers,
> Benjamin Wragg
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
