[postgis-users] Is there a Java API for PostGIS
christian.schuster at rsag.ch
Thu Mar 13 01:53:04 PST 2003
First, thanks for the tip. But now I have another problem. I have this
project I am working on. So I thought I could add all the java source code
for jdbc of PostGIS and PostgreSQL to the project and compile it there. But
big surprise. Many functions in PostgreSQL are deprecated and also with the
source code of PostGIS I was not so lucky. I think one of the reason is
that I am working with Java 1.4.1 and the source of PostgreSQL and PostGIS
was not written for that release.
There is also the following class in the PostGIS source
package org.postgis;
public class GeometryFactory {
public static byte[] Geometry2WKB(Geometry geom) {}
public static Geometry WKB2Geometry(byte[] wkb) {}
public static Geometry WKS2Geometry(String wks) {}
In all three static functions the return value is missing. There are many
other things too. So, I am wondering what I am doing wrong. I am working on
Win2000Pro system. I copied the java source code for jdbc from
postgresql-7.3.2-1 and postgis-0.7.4. Does anyone know what to do or do I
need to work over the code to update it to java 1.4.1?
Christian Schuster
Rudolf Schuster AG
Postfach 277
CH - 3000 Bern 11
http://www.rsag.ch
++41 31 348 05 30
Sebastian Bölling
<sebastian.boelli
ng at rz.hu-berlin.d To
e> PostGIS Users Discussion
Sent by: <postgis-users at postgis.refractions.
postgis-users-bou net>
nces at postgis.refr cc
actions.net
Subject
Re: [postgis-users] Is there a Java
13.03.2003 09:30 API for PostGIS
Please respond to
PostGIS Users
Discussion
stgis.refractions
.net>
you can use JDBC. See:
http://postgis.refractions.net/docs/x648.html
Regards,
Sebastian Boelling
christian.schuster at rsag.ch schrieb:
> Hi list,
> I need to insert data into PostGIS from a Java applicatipon. Now I am
> wondering if there is somewhere a Java API available for this. Any other
> ideas would be welcome as well.
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
> postgis-users mailing list
