[postgis-users] Is there a Java API for PostGIS
christian.schuster at rsag.ch christian.schuster at rsag.ch
Thu Mar 13 04:23:09 PST 2003
This could help in some way. But I do not just need to get data from a
PostGIS database. I also will need to insert them into PostGIS. To create a
geographic object is not the big problme because I just have point, line,
ellipse and polygon. The probleme is that these geographic objects are
coming from an applet to a servlet on the server which needs to make a
connection to another server (WebServer and DataServer are split and not at
the same location) where the PostGIS database is located. Also speed is not
that big issue due small data amount.
So, if anyone has ideas let me know please.
Regards,
Christian Schuster
Rudolf Schuster AG
Postfach 277
CH - 3000 Bern 11
http://www.rsag.ch
++41 31 348 05 30
             david.garnier at etu
             dier-online.com
        To
             13.03.2003 12:38          PostGIS Users Discussion
                                       <postgis-users at postgis.refractions.
                                       net>
        cc
        Subject
                                       Re: [postgis-users] Is there a Java
                                       API for PostGIS
Hello,
I'm not sure if this is exactly what you need, but I've written a little
project
that extract data from PostGIS in Java and is much faster than using the
original PostGIS code:
http://wkb4j.etudier-online.com/
The CVS is more up to date than the last release and it is far from
perfect.
Email me if you have any problems.
Best Regards,
David Garnier
Quoting christian.schuster at rsag.ch:
> First, thanks for the tip. But now I have another problem. I have this
> project I am working on. So I thought I could add all the java source
> code
> for jdbc of PostGIS and PostgreSQL to the project and compile it there.
> But
> big surprise. Many functions in PostgreSQL are deprecated and also with
> the
> source code of PostGIS I was not so lucky. I think one of the reason is
> that I am working with Java 1.4.1 and the source of PostgreSQL and
> PostGIS
> was not written for that release.
