[postgis-users] Building Postgres under FreeBSD 4.7
Norman Vine
nhv at cape.com
Mon Mar 24 10:28:37 PST 2003
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
> Norman Vine
> Sent: Monday, March 24, 2003 1:07 PM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Building Postgres under FreeBSD 4.7
> Benjamin Thelen
> > I've found entries of LITTLE_ENDIAN and BYTE_ORDER. But I don't know
> > what to do with this.
> > So I definitely took the wrong make utility, but it still does not
> > succeed.
> > I found a posting in the mailing list:
> > http://postgis.refractions.net/pipermail/postgis-users/2002-March/000817
> > .html
> > I found that I have to declare the following at the top of postgis.h
> > #define BIG_ENDIAN 4321
> > #define LITTLE_ENDIAN 1234
> > I did so and got the following messages of gmake below. Why are those
> > numbers 4321 and 1234? That seems to be a little strange. What are those
> > entries and why are they missing in the default source code?
> > Well just one Error left, the guy who wrote this posting was happy just
> > to have one error.
> > Is the installation of postgis now done? How can I check it?
> see
> http://www.cs.umass.edu/~verts/cs32/endian.html
> The following code will test your machine if the above is not sufficient
> HTH
> Norman
Lets try that again :-)
=== cut ====
#include <stdio.h>
int main(int argc, char **argv) {
static const int _EndianTest = 1;
#define IsLittleEndian (*((char *) &_EndianTest ) != 0)
#define IsBigEndian (*((char *) &_EndianTest ) == 0)
if( IsLittleEndian )
printf("LITTLE_ENDIAN\n");
else if( IsBigEndian )
printf("BIG_ENDIAN\n");
else
printf("Something is wrong\n");
