AW: [postgis-users] Building Postgres under FreeBSD 4.7
Benjamin Thelen
benjamin.thelen at ccgis.de
Mon Mar 24 11:15:05 PST 2003
Hi Norman,
Well, thanks, I've just learned what to do with the code. As I run BSD
on an Intel machine I would guess it's no surprise that your code tells
"LITLLE_ENDIAN", isn't it? Is this assumption correct?
But what does this mean for postgis_debug.h? Do I have to remove the
BIG_ENDIAN line now and rebuild it with gmake again? The "#define
LITTLE_ENDIAN 1234" entry is correct and has to remain, I assume?
Thanks,
Benjamin
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von
Norman Vine
Gesendet: Montag, 24. März 2003 19:29
An: nhv at cape.com; PostGIS Users Discussion
Betreff: RE: [postgis-users] Building Postgres under FreeBSD 4.7
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
> Norman Vine
> Sent: Monday, March 24, 2003 1:07 PM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Building Postgres under FreeBSD 4.7
> Benjamin Thelen
> > I've found entries of LITTLE_ENDIAN and BYTE_ORDER. But I don't know
> > what to do with this.
> > So I definitely took the wrong make utility, but it still does not
> > succeed.
> > I found a posting in the mailing list:
http://postgis.refractions.net/pipermail/postgis-users/2002-March/000817
> > .html
> > I found that I have to declare the following at the top of postgis.h
> > #define BIG_ENDIAN 4321
> > #define LITTLE_ENDIAN 1234
> > I did so and got the following messages of gmake below. Why are
those
> > numbers 4321 and 1234? That seems to be a little strange. What are
those
> > entries and why are they missing in the default source code?
> > Well just one Error left, the guy who wrote this posting was happy
just
> > to have one error.
> > Is the installation of postgis now done? How can I check it?
> see
> http://www.cs.umass.edu/~verts/cs32/endian.html
> The following code will test your machine if the above is not
sufficient
> HTH
> Norman
Lets try that again :-)
=== cut ====
#include <stdio.h>
int main(int argc, char **argv) {
static const int _EndianTest = 1;
#define IsLittleEndian (*((char *) &_EndianTest ) != 0)
#define IsBigEndian (*((char *) &_EndianTest ) == 0)
if( IsLittleEndian )
printf("LITTLE_ENDIAN\n");
else if( IsBigEndian )
printf("BIG_ENDIAN\n");
else
printf("Something is wrong\n");
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
