[postgis-users] new simplify version (0.2)
Vincent Schut
schut at sarvision.com
Fri May 2 06:33:21 PDT 2003
Thanks,
kind a stupid of me, puzzled that out just a moment after sending my email...
though there's 'nothing really new' it works a lot better with my sloppy
indonesian shapefiles now...
Thanks,
Vincent.
On Friday 02 May 2003 10:14, strk wrote:
> schut wrote:
> > strk,
> > to update from version 0.1, can I simply make install and run the sql
> > script on the database that currently has simplify0.1 support enabled? Or
> > should I first disable simplify0.1 support on the database (how?) and
> > then enable 0.2?
> Running make install should be enaught.
> There is no need of disable/enable again.
> Enabling script just maps a simplify() stored procedure to the shared
> object simplify.so - with make install you will overwrite the sared object,
> so any further postgres instance will use the new implementation.
> Be aware that connection opened before installing the new version will
> still use the old loaded version: in these cases reconnect to the backend
> or use 'LOAD $libdir/simplify.so' to force reload.
> --strk;
> postgis-users mailing list
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
