[postgis-users] Value too long
Oscar Testa
otesta at speedy.com.ar
Wed May 7 06:19:44 PDT 2003
I have the next problem. I modify via PHP/Mapscript the data portion of a .map file. The resulting SQL is:
SELECT nivel_imp::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from (select localidad_plano.oid as oid, localidad_plano.the_geom as the_geom, web_implem_grado.grado as nivel_imp from localidad_plano, inf_institucion, web_implem, web_implem_grado WHERE localidad_plano.codigopostal = bpchar(inf_institucion.codigo_postal,10) AND inf_institucion.id_institucion = web_implem.id_institucion AND web_implem.pampa = web_implem_grado.grado ) AS foo WHERE the_geom && setSRID('BOX3D(-73.597264 -57.9529488695652,-53.562864 -18.8021391304348)'::BOX3D, 4326 )
but i have the next error when i try to run this sql in pgadmin
"value too long for type character(6).
I'm using PostgreSQL 7.2.3 and PostGIS 0.7.3 in a win2k machine.
In other machines with the same sql run properly.
Any idea??
Regards
Osca
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030507/b0a42c5e/attachment.html>
