[postgis-users] View PostGIS layer in MapServer. (Was: Load of [....])
William C. Rowden
rowdenw at hurston.org
Wed May 7 16:00:44 PDT 2003
On 2003-05-07T11:55:55 +0000, William C. Rowden wrote:
> (<http://postgis.refractions.net/windows/WindowsHowTo.html>).
> I couldn't, however, find the "great_lakes.shp" sample, nor was
> modifying the itasca demo successful:
> msPOSTGISLayerWhichShapes(): Query error. prep_DB:Error
> executing POSTGIS DECLARE statement (0.6 failed - retried 0.5
> and it failed too). DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d()),'NDR'),OID::text from
> WHERE && setSRID('BOX3D(388107.634400379
> 5200301.16644403,500896.339019834 5313063.02375446)'::BOX3D,
> find_srid('','','') )
Again I can answer my own question. I had an error in the MapFile. I
ran the query in PostgreSQL directly:
SELECT asbinary(force_collection(force_2d()),'NDR'),OID::text
from WHERE && setSRID('BOX3D(388107.634400379
find_srid('','','') );
Obviously, this is missing the table name after the "from" and before
the "WHERE":
ERROR: parser: parse error at or near "WHERE" at character 84
The answer is RTFM (in this case,
<http://mapserver.gis.umn.edu/doc36/mapfile-reference.html#layer>).
The DATA parameter for PostGIS should be in the form of "<columnname>
from <tablename>".
Those wishing to modify the Itasca demonstration to display a layer
from a PostgreSQL database via PostGIS could use the steps in
"WindowsHowTo.html". The following illustrates the necessary changes:
shp2pgsql lakespy2.shp lakespy2 myGISdb > lakespy2.sql
psql -h localhost -U postgres -d myGISdb -f lakespy2.sql
diff demo.map demo.map.orig
187,188d186
< CONNECTIONTYPE postgis
< CONNECTION "user=postgres dbname=myGISdb host=localhost"
191c189
< DATA "the_geom from lakespy2"
> DATA lakespy2
-William
