[postgis-users] Dealing with GEOS exceptions
David Blasby dblasby at refractions.net
Mon May 12 13:37:47 PDT 2003
Just before I left for holidays (I returned today), I tried to create a
wrapper around the GEOS functions so that proper exception handling
would occur.
Unfortunately, it failed.  The code is in CVS (i think) -
headers/GeometryCAPI.h and util/GeometryCAPI.cpp. I've include some of
it below so you could see what its doing.
Unfortunately, this wrappers did not work.  It works in situations like
this where there is no stack-unrolling-exception handling:
// this function always returns 0
int f()
    try
            throw "an exception occurred";
            // never get here
    catch (...)
         return 0;
    return 1;  // never get here either
If you try something like this, where there is a stack-unrolling, it
doesnt work:
int g()
    throw "an exception occured";
// never get here
// this function will cause a SIGABORT and terminate.
int f()
    try
            g();  // g() throws an exception
            // never get here
    catch (...)
         return 0;
I'm out of simple solutions now.  The only thing I can think of trying
is using the most
up-to-date gcc/g++ and libc/libc++.  Unfortunately, this isnt a very
nice option (I'm not
even sure if it would work) because it would force everyone to use these
programs
and libraries - that could be difficult.
Another solution would be to link postgresql with libc++ instead of
libc.  Unfortunately, this would force people to have a non-standard
postgresql installation,
something I dont think is an option.
If anyone has *ANY* suggestions or thoughts, please let me know.
// This is just a simple wrapper for basic geometry functions.  See the
// Geometry type documentation for exact definition for these functions.
// Because some C programs might have trouble calling C++ (most notably
// postgresql, PERL, PYTHON, JAVA, etc...) when there is triple indirect
// access  (postgresql -> libpostgis -> libgeos).
// A more technical discussion of this bug is at
http://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=37
933
//  Basically, if libc is loaded before libc++ exception handling might
be comprimised.
// This class solves this problem.  It basically wraps try..catch blocks
around the obvious
// calls to GEOS functions.
// For functions that return a boolean (ie. g->isValid() or
g1->disjoint(g2)), these functions
// return:
//     0  -- FALSE
//     1  -- TRUE
//     2  -- ERROR OCCURRED  * usually due to invalid geometry or
robustness failure
//  For functions that return objects (ie. g->asText(), g1->relate(g2)),
these functions
//  return either the appropriate object or NULL if an error occurred.
// Usage:
//  if you want to do
//     g1->relate(g2);
//  then you do:
//              GeometryCAPI *capi = new GeometryCAPI();
//              char result        =  capi->relate(g1,g2);
//              if (result ==2)
//                      //handle error
//  GeometryCAPI also handles geometry construction.  When you create a
GeometryCAPI,
//  you also make a new GeometryFactory (see GeometryCAPI constructors
vis-a-vis GeometryFactory).
        Geometry *GeometryCAPI::createPoint(Coordinate *c)
                try{
                        Geometry *result =factory->createPoint(*c);
                        return result;
                catch (...)
                        return NULL;
char GeometryCAPI::touches(Geometry *g1, Geometry*g2)
        try {
                bool result;
                result =  g1->touches(g2);
                if (result)
                        return 1;
                else
                        return 0;
        catch (...)
                return 2;
